2015 XJR additional radiator fan.
Hey guys,
Been talking with Robert at Mina Gallery. After installing pullies and a tune he recommends adding a high flow electric fan, 12” he said, to the front of the radiator / heat exchanger to help keeping the charge cooler.
Is this a job anyone has undertaken? If so, what fans did you get and where did you wire them in?
Here’s a little of running her down the road after being out of town for a few weeks.
https://youtu.be/FM_qxxZL5Zg?si=rNTAqxEalkCpkaJO
Cheers!
Aaron
Cheers!
Aaron
Just a thought: Would it be easyer to install 2nd radiator from 3.0L diesel version? (front of left front wheel) As far i have been understand the diesel are only version to have 2nd radiator?
Moutings are present and parts / open grilles well available as 2nd hand, since most selled verisons on EU side were Diesels.
Not sure how much more air can be pulled thru radiator even adding 5 fans to it...Every fan added create also airflow restriction.
