2016 -2019 XJ InControl Touch Pro 8” to 10.2” factory upgrade
#101
Help ! :)
@xdave , thanks to your great help, I was able to get this job done successfully. And @Cambo helped replace UIP for use CarPlay, is also very grateful. It's been 3 years since I bought the XJL. Display / CarPlay work has been the most satisfying.
1. PAM
My PAM was GX63-15C859-DL. I reprogrammed it, but it failed and it made to be brick. My choice is "GX63-15C859-DM". I have purchased 2 "-DM". I tried to reprogram one of them, but it also turned a brick. If you're not confident, just buy "-DM" and just replace it(do not reprogramming). There is no problem at all to use.
2. IPMB
Old IPMB was "FW93-14F026-AJ". If you can not change the camera mode without replacing the IPMB. I bought "HY32-14F026-AM" on eBay and replaced it. Even after reprogramming, my car didn't recognize this module. Unlike PAM, no problem occurred during the reprogramming process. I bought "JJ32-14F026-AD", again and changed the calibration software to "-BD". It is perfect!
3. CarPlay
My Jag had LOW_LINE UIP. If you force the "Smart Phone Pack" to be activated, only Android Auto will be available and causes many problems. I replaced it to HIGH_LINE UIP, and connected it used HSD. CarPlay works perfectly, now!!
Thank you everyone!
1. PAM
2. IPMB
3. CarPlay
Thank you everyone!
Can you PM me ?
Regards
#103
Hi,
Really interesting article. I have specifically joined to ask a question sorry if this is frowned upon. I am a JLR driver, I drive a Discovery Sport 2017 2.0 diesel which is a mix of all JLR stuff. I have the 8" Touch system and was advised on a few DS forums that it cannot be changed to the 10" system?? But it looks like you have done this, on a few Jaguars?? I believe they are the same infotainment systems with the same part numbers etc. I used to drive a Range Rover Autobiography and I was able to re-program it using a Britbox ODBII adapter so LR stuff can be re-programmed. The DS is capable of being chipped so surely it can have other parts of the configuration tweaked in my opinion. Do you have any information on whether this can be done or not?
Any info would be happily passed on to the DS forum who do have a few threads on this.
George
George
#104
Hi,
George
George
#107
Hi,
George
George
What you are asking is technically possible but it's not really financially feasible and it would take a great deal of time and a really skilled individual.
#108
Hi zYx, you seem to be the most recent conversion in the UK. Could I ask how much you paid for the bezel and bracket? They seem hard to track down used, so expecting dealer prices.
I'm new to XJ ownership, so expect I'll be needing an SDD cable and SW anyway, but have coded on the older BMW architectures. The car I'll be upgrading has reverse camera only, @xdave did you ever get to try this upgrade on that configuration? Wondering if I'll need to upgrade the IPBM or not?
#113
#114
#115
#117
The fascia was £100 and the bracket was £200 but it’s gone up now.
second-hand dual view LCD (from f-pace) was £200. You WILL need a new IPBM module if you want to upgrade cameras. This could cost between £150 for used and I think around £600+ for new.
You’ll need a proper power supply and I went with Charge Doctor (£300) and a Diagnostic Associates’ “DA Dongle” cable (£300) for programming.
I still love my big screen with Apple CarPlay 👍🏼
I’d suggest you read the entire post from the beginning as everything has been explained above including part numbers. I got some parts on eBay (ie LCD) and what I couldn't get on eBay I got from Britcar.com but try your local main dealer, you might be surprised.
Let me know if you need help with anything.
#118
#119
Hi @ndg
When you say 'upgrade cameras', do you mean to 360 view or just to the 10.2" format? I'm not too fussed by 360 view (although it is a nice feature), but I would like the rear camera to look right and all soft buttons to be available. I've read through the thread a couple of times and my only concern is that no one seems to have configured an IPBM for just a rear camera, only in conjunction with 360 view.
#120
