2016 LED headlamp retrofit to earlier cars (with full functionality)
#181
So, with much guidance from this thread I am preparing to upgrade the headlights on my 2015 XJ Portfolio for the LED beauties of the later MY models.
A test connecting harness is being made up for me (I'm doing the "method 2" as I don't have the ***** to break into the headlight units) and should be ready to try on Monday. If it works (the OP does say he didn't try it himself), the auto electrician I've employed is going to make up the proper harnesses and I shall fit the headlights next weekend. Photos will follow.
#182
#183
The auto electrician who's making up the harnesses for me is going to miniturise the relays and diodes and put everything onto a pcb. The harness should then just be narrow loom with a bulge in the middle.
#186
Yes. Glad you brought that up as that has been my only complaint.
After the change out it just did not seem the lights were working very well. I lived with it figuring my old eyes were the problem.
I finally set up some measurements on my garage wall and raised the lights and boy do they work great now!!
One other question? Do your automatic high beams work OK? Mine hardly ever even come on if left in automatic. Looking for some
adjustment or setting but have not found anything. On older Fords I could adjust the darkness that the lights would come on so I was looking for something similar.
#191
OK, quick update: As posted previously, I had the test loom made up and it worked perfectly. The guy doing this for me has now made up the finished looms with an intermediate box containing a small PCB with the three relays and two diodes, Great job and looks very OEM.
But . . . when we connected and tested this one, everything works . . except the indicators. The other indicators on the car are flashing away so it must be an internal thing. We swapped the looms just to make sure it wasn't a miss-wire but same thing.
So, what's different between the test loom using the large relays and this finished loom? The micro-relays (rated exactly the same as the larger ones) and the circuit board itself. A resistance thing?
He is going to remake the test loom and compare the resistances but in the meantime, all ideas are welcome.
#192
If the finished circuit is functionally the same, then resistance is a good bet. The fuse box that controls the lights monitors the current draw of each individual circuit to detect failed LEDs. It may be seeing too high/low current being supplied and is shutting down that circuit. Do you see double speed flashing of the other indicator lamps?
#193
My guy is going compare the resistances between the original 'test' loom and the 'finished' one. I'll post the outcome.
Thanks for your help, Dave.
#194
That symptom is the CJB fuse box thinking an LED is out and is shutting down the circuit, so that narrows the cause down to the current being drawn by the relay. Just an educated guess but you may need to add a resistor in series with the coil - your auto electrician should be able to track it down.
#195
Yes, even I (an electrical novice) noticed the built-in resistor across the coil on the large relays, not present in the micro relays. My electrician has already commented about introducing a resistor.
#196
#198
#199
Yes, it was an issue with the resistance across the micro relays and so after adding the resistors the adaptors have been retested . .
https://youtu.be/Id0uj1nnp4s
These are the harnesses. I'm very pleased.
Should have the headlights swapped this weekend.
#200
That is a very smart job. Enjoy the new lights! If your electrician is prepared to make additional harnesses up there would be a market for these on eBay...
I would be interested to find out if you get the AFS warning lamp flashing when you start the car (to ignition) with the lights set to manual dipped on and the switch forward in the full beam position. If you could test that and report back to the thread that would be helpful for all.
