XJ ( X351 ) 2009 - 2019
2016 LED headlamp retrofit to earlier cars (with full functionality)
Old 02-27-2020, 02:00 PM
OBC John's Avatar
They're being swapped on Sunday, Dave so I'll let you know re any fault or warning lights on start up.
My electrician has said he will make more but to order only.
  #202
Old 03-02-2020, 06:01 AM
OBC John's Avatar
The headlights were swapped over yesterday. What a ball-ache having to drop the bumper which needs both front wheels off. Fortunately, there are two members of the UK forum that I'm a member of who together are known as "Sunday Club" (work it out). They help out forum members for things like brake pad and disc (rotor) changing, dashcam installs, etc., and have a large garage with a platform lift. This makes raising the car very straightforward and a lot safer than propping on axle-stands.
The swap didn't go without a problem (or in English, a squeaky bum moment). After the headlights had been connected but BEFORE we put the bumper back on, we decided to test them. Initially all seemed well but then strange and random things started to happen with flashing LEDs, indicators not working, one side working but not the other and more. But I then remembered the issue with the fuses and checking F24 & F25 (BOTH of which were 5 amp by the way) found both blown. Replaced with 10 amp and checked again. Still random problems. So checked what other fuses may be involved; F49 and F50 are the adaptive headlight motors L & R. Checked (again, both 5 amp) and yes, both had blown. Replaced with 10 amp. Re-test.
ALL OK!!
No dash fault lights and the auto high-beam assist works perfectly.
It has now been 24 hours since they were fitted and so far so good. I may have to slightly adjust the RH beam - it looks a little low - but apart from that, all good.
Once again, my thanks to xDave for the invaluable information contained in this thread. Kudos!
The following 2 users liked this post by OBC John:
xdave (03-02-2020), XJsss (03-02-2020)
  #203
Old 03-02-2020, 06:39 AM
XJsss's Avatar
Nice job and would love to buy a set of the adapters if your electrician friend is amenable to making additional sets as I'm sure there are others that would be interested. Also, love those Blackvue Dash cams as I've an older set of 650s. The RH lamp looks low to me too as the hotspot appears too close.
  #204
Old 03-02-2020, 09:53 AM
clubairth1's Avatar
Received 2,357 Likes on 1,857 Posts
Very well done!!
Any idea on pricing or if they will be sold?
If not too expensive I might replace my home made harness with yours.
  #205
Old 03-02-2020, 01:40 PM
OBC John's Avatar
Here are a couple of night time shots . .
DRLs
Dipped beam
High beam
  #206
Old 03-03-2020, 02:15 AM
christ's Avatar
I achieved a similar effect by writing off my 2010 Portfolio and replacing it with a 2017 Autobiography.
My way was probably more expensive, in hindsight. (... although there were other side effects)
xdave (03-03-2020)
  #207
Old 03-03-2020, 03:50 AM
OBC John's Avatar
I came by my XJ in exactly the same way - writing off my 2010 XF Portfolio (well, having it written off by an Audi).
Which engine do you have? If it's the Euro 6, 3-litre diesel, have you had any oil-dilution issues?
  #208
Old 03-03-2020, 05:35 AM
christ's Avatar
It is the Euro 6, 3-litre diesel, but I haven't had any oil-dilution issues yet (largely, possibly, as I have only had it for 5 days!)
  #209
Old 03-03-2020, 06:03 AM
OBC John's Avatar
I'd have loved the Autobiography but finances limited me to a 2-year-old (when I bought it) Portfolio.
If you're doing a lot of miles in order for the DPF to regenerate properly it won't be an issue. But the dealer should have mentioned it if your daily drive is only a few miles. I'll drop you a PM.
  #210
Old 03-03-2020, 06:45 AM
christ's Avatar
Thanks. I will watch the oil level with interest!
  #211
Old 03-04-2020, 02:49 PM
OBC John's Avatar
I have just PM'd the two FMs who said they'd be interested in those wiring connectors with the email address of the guy who made them. I don't want to put it on the open forum for obvious reasons. If anyone else is interested, let me know.
  #212
Old 03-04-2020, 08:07 PM
gagman66's Avatar
I'm very interested for ones for AFS LED Headlights.
  #213
Old 03-05-2020, 02:24 AM
Peacock Prestige's Avatar
Wonder if someone could help me fault find where i have gone wrong on the conversion doing it the second less complicated way?
My drivers light all works fine so i have followed the wiring correct
My passenger side is an odd one has the following faults
DRL does not work
indicator only works if side light or head light is on
headlight flashes for about 20 seconds when they come on
high beam flashes
it is almost like the headlight is using power or earth from the side light if that makes sense.
i carried the changes out to the car loom not a separate loom, the colours do not match the drivers side so cant cross reference it
Any thoughts of how to approach fault finding is welcome
  #214
Old 03-05-2020, 04:06 AM
OBC John's Avatar
DRL does not work
high beam flashes
Worth checking the 4 fuses I mention in post #202.
XJ8JR (03-06-2020)
  #215
Old 03-05-2020, 05:09 AM
fuse 50 was blown!
All works perfect now.
Cant believe it was something so simple
many thanks for your help
xdave (03-05-2020)
  #216
Old 03-06-2020, 08:51 AM
clubairth1's Avatar
Be sure and read this entire thread. Did you replace them with 10A versions?
I went thru this and finally ended up with 10 A fuses.
That was almost 2 years ago and no problems since then.
  #217
Old 03-11-2020, 06:22 AM
OBC John's Avatar
A quick update. Had the headlights on for 10 days now and all OK. But I have had the adaptive headlight warning light come on once or twice. No pattern. Seems random.
The system is working (the headlights swivel when turned on and then centres) and the warning disappears after an ignition reset.
Any ideas, anyone?
  #218
Old 03-11-2020, 07:32 AM
xdave's Avatar
Hi John,
Did the AFS warning come on immediately after ignition, or randomly during a trip?
Was it only at night when the auto lamps would come on immediately?
Do you remember if the lighting stalk was in the full beam position when the warning was shown?
  #219
Old 03-11-2020, 08:09 AM
OBC John's Avatar
Originally Posted by xdave
Hi John,
Hi Dave. In order;
Came on randomly during trip.
Lights were on manual (turned on during rain).
Only on dipped beam. (Did I flash anyone? Honestly can't remember. But the stalk was in the dipped beam position all the time.)
  #220
Old 03-11-2020, 08:22 AM
xdave's Avatar
Thanks, that confirms it is not the issue we are already aware of.
I would be interested to see the stored DTCs from your car which should give the reason the CJB reported a fault. As it is seemingly random then if the hardware is OK I would suspect a current plausibility issue is being detected. Heavy electrical loads like wipers and all lights on, maybe the demister, etc, could be dropping the voltage just enough that the CJB is seeing the current drawn tip over a detection preset. That is why ignition from cold with full beam on sometimes triggers that warning (but not always).
Are you ale to send me the part nos for the relays and components used by your electrician so I can check out the datasheets?
Quick Reply: 2016 LED headlamp retrofit to earlier cars (with full functionality)
