2016 LED headlamp retrofit to earlier cars (with full functionality)
#141
Its a bit hard to tell how bright yours actually are due to the strobing effect of the camera.
1) I used the adapter harness method
2) They are US-spec lamps (I appreciate that they lightly smoked the orange reflectors on this version, btw; although I would've preferred the clears)
The J Blades are very bright in the garage with the garage lights on (low beams off) and very bright with the low beams on at night. During daytime driving, I can still see them reflecting off of the car in front of me if we're close. But if you get out and look at them from the front, they just don't seem to be as bright as they should be or as bright as other XJs I've seen.
#142
#144
Hi XDave,
I been wondering about this for a while. I purchased a set of the AFS led headlights from a shop in England about a year ago. They made already been modified to fit pre 2012 cars and were simply plug-n-play. All functions work, including the cornering lights, and have never had a warning light come on. My question is since the headlights do not appear to have been opened up, are all the required modifications done by rearranging the pins in the plug or is there something else involved.
#145
Has anybody had any battery issues after installing the new headlights? I started getting the Low Battery warning semi-frequently after installation in December and its progressively gotten worse. My battery voltage is reading 12.2 in the off state so its definitely getting low. Before I just put in a new battery, I'm wondering if there's some possibility of a parasitic draw somewhere in the lights or harness, or is it just a timing coincidence?
#146
No. I have had them on my 2014 XJR for over a year now with the same battery the whole time. Only the 2 small issues noted above.
The J-blades are a bit dimmer than on the factory installed LED's during the day.
If the car is turned off with the bright lights on. You will get an adaptive headlight error light on the dash on the next start. This goes away by turning the car off and restarting.
Just don't shut it down with the brights on again.
So probably just battery time.
XJ8JR (04-08-2019)
#147
Anyone know what the difference is with the US spec part numbers that end with a "C" instead of a "B" like posted above?
#149
#150
#152
Randy Mounts (10-09-2019)
#153
#154
When I bought it, he told me that is the last pair available in the UK. You may try to ask him again.
Hope this helps.
#157
#158
#159
#160
