2016 XJ - Infotainment system issues
Hi - I have a 2016 XJR-sport, but appear to be having a number of issues with the Infotainment system. About 50% of the time when I start up there's some form of issue - bluetooth won't connect (or disconnect when not working), screen goes black, music does not work, maps refuse to fire up.
Seems to be more often when I jump in the car, start the engine and immediately put in reverse. Appears that doing anything before Infotainment systems is fully booted causes problems.
Anyone else seen similar issues?
I think you just resolved your issues - give it time to fully boot up.. Nevertheless, I'd discuss this with your dealer since you're still under warranty. Better still, bring it in so your dealer writes up a service ticket so it's documented in your car's file in case it doesn't get better. The infotainment/touchscreen system is expensive, and you want all repairs to be covered by the warranty.
