2017 XJL seat bolsters inflate but seem to deflate over time
Good afternoon XJ (X351) owners/drivers/lovers,
I have noticed, of late, that when I "tighten up" the seat bolsters (driver side), they seem to "loosen" (deflate) over the next 15-20 mins, and I have to "inflate" them again. Anybody else run into this? Is this a "leaky bladder" problem? This was a certified XJL. Presume that would be covered under warranty? (I say "presume" because it sounds less like "***-ume"--so "presuming" only makes a "pre" out of me, rather than an "@ss"). Thanks all for your input!!
Hi,
On both my XJ's the seat back lumber cushions will deflate over time 1-2 days, after all it's an air bladder with an exhaust. I think 15-20 mins is excessive IMHO. I tend to have mine at @75% max.
You should point out every single niggle, creak and gripe before your warranty expires, after that it's on your wallet.
wombat
wombat
KalamazooJag (05-19-2021)
Not pertinent to this instance or short time span (unless in an environment of rapidly changing outside ambient temp/pressure), but as far as over a longer period of time...
Air pressure is relative. So as barometric pressure (and temperature since they're related) changes, so changes the pressure within the bladder.
Same with tires, suspension, fuel mixture...
I imagine the design of the seat air bladders include a pressure relief valve, so that if outside pressure drops much (relative to the seat's internal volume/pressure), it won't cause the bladder to form a leak.
Maybe not, but I can't imagine the design engineers wouldn't - it ain't rocket science.
