4 seconds delay in reverse
Received 3,928 Likes
loulizjag, I would start with checking the tranny fluid level to make sure that it is where it should be. If it is a little low, it can cause what you are seeing. After that, I would have to think that you have a solenoid that is starting to go/sticking and that is leading to the slow response.
Hopefully someone that has access to a maintenance manual can look this one up for you. I am on travel and don't have access to mine. Granted, if no one has responded by Friday, I will be back home and will be able to provide more detail then.
loulizjag (08-01-2017)
loulizjag, like what the video shows, in short, to check the level in the tranny, you want to place the vehicle on jackstands (get it up in the air so you can be under it) and have the car level. From there, you need to get the fluid to between 30C and 50C in termperature (will reach this point by starting the engine and letting the car idle for 2-3 minutes). With the engine running, cycle the gear shifter through all the positions to ensure all paths inside the tranny are full (do not forget to keep your foot on the brake). At this point, stop the engine and get under the car. Remove the fill port plug and ensure a slight drizzle of fluid comes out. If no fluid, the level is low and you need to add fluid in 0.5 pint increments until you see fluid start to come out the fill hole. Once fluid starts to come out of the fill hole, install the fill port plug (manual recommends a new plug) and torque to 35 nm (if using the jaguar special tool or any other adapter to a torque wrench, ensure to recalculate the torque value you go to based on changing the length of the torque wrench, any questions about this, let me know).
