5.0 SC Power Upgrade
Stock 5.0 sc can go past 600hp with Alpha Jag Tune
https://www.jaguarforums.com/forum/x...g-time-256504/
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
it's not, torque numbers would be similar
__________________
we have multiple XF, xfr jaguars with over 700 hp ,including one with nitrous pushed very hard at tracks and doing 10s in 1/4 mi and here are no transmission issues . So 600 is not a problem at all for this transmission.
__________________
Say what you will - if your transmission is a newer trans, then that power may be attainable.
The 6HP28 is listed on ZF's data sheet as being capable of 550 ft lbs. There are always engineering factors of safety, but there are tradeoffs when heat and friction exceed expectations, so it's not something that someone can say is "no problem".
The newer 8 speeds can handle more.
#28
__________________
#30
#31
https://www.wardsauto.com/news-analy...p-transmission
I truthfully could not find a more definitive confirmation, but this is an old article. I confirmed in person as my best friend works for ZF and designs torque converters. He had a spec sheet issued by ZF I was reviewing and ballpark max is 550 ft lb. Anything more is just engineering data they typically don't release to anyone but the OEM. Again, yes you can go higher than max. The rest is risk/reward and dealing with the unknowns. I argue that 516/550 for a transmission will not make a material impact. This is not a tire where they rate 4/5 times lower than max burst. They do go above and beyond listed for all transmissions.
8HP70 is listed as 516 ft lb on paper.
I don't believe most limit to 516 because that's all that can be done, but I am betting most do that due to the chain of liability that can cause emotional or financial heartburn down the road since that's what ZF lists. I won't put words in others mouths though.
Panthro (07-27-2024)
#32
Sorry, I believe you are right. To be honest, I thought the 8 sp had higher input torque max.
I truthfully could not find a more definitive confirmation, but this is an old article. I confirmed in person as my best friend works for ZF and designs torque converters. He had a spec sheet issued by ZF I was reviewing and ballpark max is 550 ft lb. .
#33
Just for reference on the earlier zf on 4.2xkr The torque is over 500 with our tune And it's handling it just fine and taking quite a bit of abuse
__________________
#35
4.2 cars use zf 6hp26
__________________
dmchao (03-03-2022)
