5.0 timing chain
5.0 timing chain
looking at this video. there seems to be a left & a right for the guides.
has anyone replaced the tensioner guide and chain guide? i just want to be sure that the parts im looking at are the right parts for the replace job.
timing chain C2Z22078
tensioner guide C2Z28431 - supposed to have left and right piece?
chain guide C2Z28429 / C2Z28430
chain tensioner C2Z28428 - do i need this?
am i missing anything?
below are for the oil pump. is it necessary?
chain C2Z20573
guide AJ812448
tensioner AJ813839
chain C2Z20573
guide AJ812448
tensioner AJ813839
Usually if the guides have been bad for a while you'll get wear to the gears asa well. Could be from bad tensioners. Might as well do the whole job and not just the guides. Mine were bad too, especially the driver side. So with the timing chain off my indie showed me it had cause visible wear to the teeth on the upper gear for the cam, and that also had been causing minor damage to the whole driver side head by it being driven when the tensioners and guides were bad. Not sure about the exact parts but I do have the printout showing the whole job with parts if you need it I'll find it and take a pic. Lmk.
I operated to drop in a new motor rather than deal with all the repairs. But I still have the work order from when it was diagnosed.
jagmt (07-01-2018)
though I was told that the tensioner pulley bearing might also be a cause for the ticking.
dan02xk8
03-30-2019 11:41 AM
slanham
General Tech Help
02-01-2014 07:34 PM
85_305
12-02-2009 07:07 AM
