AC Compressor Removal?
Progress update - I began my R&R of my compressor today... it is a wee bit of a challenge as they say, but I did get it out (thanks for all documents and pics Clubairth1!)... my new compressor and old one matched up perfectly (PXE16)...I decided to replace the desiccant bag as well, but unfortunately the new one from Rock Auto isn't the right one, so I'll shop local parts stores to see if I can find the right one...I'll be doing re-install over the next couple days, and I'll update again once completed...
Finished the install today, vacuumed it down for about 4+ hours, put in ~24.7 ounces of R134, and wahlah, I have cold A/C again!!! Below are some pics of the old and new desiccant bag and plug... I got mine from NAPA, they were closer to me than Autozone...
#28
Thanks! I added some pics of the desiccant bag/plug... It was a bit of a challenge to get out, the 10MM hex wouldn't move it, it was just rounding it out inside...so with some southern ingenuity, I used some long needle nose pliers and a long screw driver to get it out ... pushed the pliers up into those slots on the outer rim of the plug, and used the screw driver to twist it, and it came right out!!!
#30
Good job at the DIY repair. Anytime your system needs to be evacuated for any reason, it seems like you're looking at least at a $500+ repair bill.
#31
judaji
07-30-2017 05:59 PM
slownlo
06-10-2017 08:12 PM
