adding interior console ambient lighting strips
has anyone added the popular XF mod where el wire is wedged along the center console, worked really well on the XF where the strip could be run seamlessly from under the armrest to plug into the lighter port inside, clean install without tapping into any wires:
https://www.jaginfo.org/threads/addi...ination.49465/
wondering if this can be done on the X351 along the lower (and maybe upper as well) console plate, but seems would need to run under the plate to the lighter port and now sure how to best make it look seamless
I gotta say your picture looks great!
Bernie you bring up something that I wish they had in the XJ and that's the ability to turn off the blue halo's around the vents. On long drives the blue reflection in the side mirrors does become tiring. Love the look but the reflections are a killer!
Similar to reflections off the chrome on the center console. I kinda fixed that by resting my right arm over that area when the reflections get in my eyes.
Dwayne
Dwayne that's a funny story!
We also played with the colors for a while then just lost interest.
Then I noticed that it had gone back to white? I changed it and some time later again back to white.
Did more research and there was a tsb on the color system reverting to white or blue after cycling the ignition key.
I never even bothered to get the software update as it just seems so unimportant to me a driver?
and guessing it could have also been fed into the lighter port without splicing as well
can you describe how/where you pried the console up? I tried using a plastic trim lifting/wedge tool a few places along the bottom without much luck, trying to to break anything holding it down
The console trim is lifted under the chrome piece. The black (or perhaps blue now) plastic piece is attached to the chrome with fasteners. You can see a few pics here of it that shows the mounting tabs. Basically open the console cover and start prying at the end beyond the ash tray. Gradually work your way forward. It comes up with the ash tray included. If you want to remove it completely you will first need to pull the upper console bezel and then the controls inside it. I think it took T10 torx to remove the control unit fasteners. Then the whole thing will come up and leave just the shifter and the cup holder behind. You will have to unplug a few connectors after you get it loose if you want to remove it entirely.
Once you do it a couple times, it takes about 10 minutes to do it all.
I attached the removal procedure from the manual.
Can you describe more clearly where exactly to start prying
I'm prying the plastic up from the chrome correct? I can get under it but the fasteners(?) won't allow it to lift up feel like something is going to break, how does the chrome come up there's no way to wedge under it at all
daboss085
09-11-2013 04:24 PM
