XJ ( X351 ) 2009 - 2019
Aftermarket Wheels
Old 04-22-2022 | 08:03 AM
carguy66's Avatar
Default Aftermarket Wheels
I have a 2016 XJL AWD with stock 19" wheels. I'm looking for aftermarket 19" wheel recommendations.
Old 04-22-2022 | 09:38 AM
MV Rider's Avatar
Have had these on my 2015 XJL AWD for about 2 years. They are available through Car ID. but I go mine at Discount tire. They are a forged aluminum wheel and you can use your original Jaguar lug nuts and Jaguar Growler center cap.
Old 04-23-2022 | 11:37 AM
Stuart S's Avatar
You can find many sources on the internet. Just make sure you get a written guarantee that the aftermarket wheels will fit and if they don't you can return them at the seller's expense for a full refund. And be sure to pay with a credit card, not a debit card or check, so you can dispute that charge and get your money back.
I would stay with the OEM wheel specs - same width and offsets. Of course, the bolt pattern must be the same. Otherwise, the suspension geometry may change and adversely affect ride, handling, and tread wear.
See: 19 inch Element Wheels for Jaguar X351 XJ
I have no affiliation with that vendor and make no recommendations, either positive or negative, about them.
Good luck with your search!
MisplacedPriorities
05-09-2021 07:25 PM
Dwight Frye
08-07-2020 04:45 PM
2011XJLSupercharged
04-15-2014 07:26 AM
jaguny
09-22-2012 02:47 PM
