Air Conditioning Issues
Location: Mooresville, NC (Race City USA), home of most NASCAR teams.
No, but then again my 2011 only has 34,131 miles. or one-third your mileage. Freon is difficult to seal, so I suspect this problem is rather normal at your mileage. Let us know how your problem is resolved.
Is your problem solved? I had this same issue with a Volvo XC90. Turned out to be a sensor. The sensor that shuts off the compressor keeping it from freezing up. Car would blow cold... freeze up and start blowing hot. I would shut it off... ice would melt... then it would blow cold again.
Yes problem solved. Very low tech solution. After having the car for a week and scratching their heads they pulled the cowling cover off the radiator and discovered that the radiator core was plugged with dirt and debris from all the blowing dust in the area. They washed out the radiator core and it runs like a champ. Its like the engine couldn't breath do to the plugged radiator coil.
99xk8guy
06-05-2023 06:28 AM
