Air conditioning problem
Just out of warranty and the A/C isn't working properly. There is cool air coming out, but only slightly cold. Does not matter what A/C fan speed it is at and all the vents are same temperature. Does anyone know where the interior cabin temperature sensor is located? I will try to clean it before going to an A/C specialist or dealer. I checked to make sure the condenser wasn't plugged up with leaves and debris. Not much or any info on X351 A/C issues.
Took the car to an A/C specialist and left it for a day. Got a call that all the pressures were good and everything checks out and is working perfectly. Wierd! Before I took it in, it would barely get cold. Now it works perfectly. Been working great for the last two weeks. Well that was a cheap fix.
Max432 (08-04-2019)
Stuart I did have the compressor on. The center button was lit and I also engaged the two side buttons. I did have the dash buttons replaced as a whole unit due to the sticky buttons issue under warranty. Working fine still! Luckily I have an honest A/C shop near me that is capable of fixing anything a/c. They told me there was plenty of freon and don't let anyone add any. Lynn's Auto Air in Downey CA.
Solved The problem was the radiator fan went out. The A/C went out again and the temp warning came on. I noticed that the electric fan was not coming on. Took it to a Jag specialist and they confirmed it was the electric fan not working and and not the climate control or the compressor. Replacing the fan seems to have fixed the problem. Changed the engine oil too, just to be safe.
XJL (10-02-2017)
Thank you so much for coming back with the solution!
This is critical for our forum as there will be others with the exact same problem.
With the complexity of the car I am surprised the fan failure did not set some sort of code?
Is there one or two cooling fans?
I am a new XJ owner.
