Air Ride Suspension
Air Ride Suspension
Hey Jag family, I have a 2014 x351 that was involved in a rear end collision , i got the body work completed resolved some issues with the dash not working and radio (had to do with the rear harness from back bumper being damaged) but now i am having a issue with the rear air suspension on the dash it says to service the air suspension. I have put a new air compressor in the vehicle it does turn on for a slight min then goes off ? Maybe there is a sensor or separate module i need to look at ? The vehicle isn’t fully together yet but most wiring is connected other then the module for the trunk open and close and back up camera and trunk release. Any help would be greatly appreciated thanks in advanced .
You may need to plug in that module. Keep in mind that all the modules share a common data bus. So, having something unplugged can cause mysterious things to happen. What can also help is if you can get a higher end code reader, you can plug into the OBD port and you can download the chassis codes (CXXXXX where XXXX is 4 characters). This will help pinpoint what the car is seeing as an issue and narrow what you may be looking at as a problem.
76driver
25
04-07-2021 10:21 PM
jag2020
03-03-2010 09:58 AM
kandaonly
11-03-2008 06:25 AM
