XJ ( X351 ) 2009 - 2019
Aluminum Replacement for OEM Plastic Coolant Pipes
Old 10-01-2023 | 10:19 AM
Stuart S's Avatar
Originally Posted by Meanmugga
Just ordered a set for my 3.0L ... friend said he smelled coolant. And I'm not taking chances.
where is the link on how to replace? And list of items/tools needed
Most likely, it's your water pump and not the coolant pipes. How many miles on your XJ and was the water pump ever replaced?
QP7 (10-11-2023)
  #42
Old 10-01-2023 | 12:12 PM
2018XF25T's Avatar
Check on YouTube:
Jaguar XJ, F-Type, F-Pace, XF, XE, Range Rover and LR Discovery with a 3.0 have the same engine. Search those on YT on how to replace cooland pipes.
The following 3 users liked this post by 2018XF25T:
Meanmugga (10-01-2023), QP7 (10-06-2023), ralphwg (10-01-2023)
  #43
Old 10-01-2023 | 12:33 PM
NBCat's Avatar
Here are the aluminium pipes installed on an AJ126:
The following 5 users liked this post by NBCat:
2018XF25T (10-01-2023), JgaXkr (10-03-2023), Meanmugga (10-01-2023), QP7 (10-02-2023), ralphwg (10-01-2023)
  #44
Old 10-01-2023 | 12:51 PM
Meanmugga's Avatar
My XJ is a 2016 with 47k miles as of yesterday. No knowledge if the prior owner replaced the pump.
Where is a good place to order the pump? Or is it oem only?
  #45
Old 10-02-2023 | 10:36 AM
clubairth1's Avatar
If your interested in upgrading to the Aluminum cooling pipes there some kits that might be what your looking for?
Cooling System Upgrades
I have a couple of complaints with the above kit? For you 3.0 SC guys you can also get the rear water manifold in metal. Another VERY worthy upgrade! But the kit will get you the plastic version.
The water pump to oil cooler brick pipe also in Aluminum to replace the factory plastic version. Cheap at $15.
Al. Tube from WP to Oil Cooler Brick
Here is the rear water manifold in metal and it's a bit pricey so you need to decide if you want to upgrade that or not. Now with the cost of labor if your not doing this DIY I would think hard about adding that metal part. Everything will be apart at this point and almost no additional time required to swap that rear manifold out.
Al. Rear Water Manifold
The following 3 users liked this post by clubairth1:
jahummer (10-02-2023), Nedoerr (10-02-2023), QP7 (10-05-2023)
  #46
Old 10-03-2023 | 01:00 AM
lotusespritse's Avatar
Al. Rear Water Manifold.
I just did that job on a 3.0L 2014 Range Rover Sport, and I thought, while I am here with the supercharger off, I should just change that rear manifold. Boy that was a lot of extra work!!
  #47
Old 10-03-2023 | 09:06 AM
clubairth1's Avatar
It is but we have had several guys change it WITH the SC in place! I can't imagine even attempting that without removing the SC!
  #48
Old 10-03-2023 | 03:36 PM
Me neither.
  #49
Old 10-03-2023 | 04:04 PM
amc2023's Avatar
Are there any known write ups with pics or videos showing how to even attempt to change without removing the SC?
  #50
Old 10-03-2023 | 08:55 PM
Step 1: Buy one of these
QP7 (10-05-2023)
  #51
Old 10-04-2023 | 08:07 AM
Tstealth32's Avatar
I've replaced the rear coolant pipe on the 3.0 without taking off the SC. It's definitely tight, if you have big hands, I don't think you'd be able to do it. You'll need a low profile ratchet like this .....
GEARWRENCH 35 Pc. Microdriver Set - 85035 https://a.co/d/9sXE1H1
Wipers, the the wiper shield will have to come off.
The wiring harness will get wiggled around some stuffz there is just enough slack.
Your back will hurt.
Your hands will get cut up.
It'll take about 4 hours.
I'm mad they didn't have the metal version 2 years ago!
The following 2 users liked this post by Tstealth32:
amc2023 (10-04-2023), QP7 (10-11-2023)
  #52
Old 10-04-2023 | 01:03 PM
2018XF25T's Avatar
I've seen videos on YT. Removing the SC is time consuming but fairly easy. Organize all the parts you removed so that it'll be less hastle when you install them back in.
  #53
Old 10-11-2023 | 01:24 AM
Meanmugga's Avatar
Purchased these... and ready to install.
I want to know are they the "revamped" versions that fit properly?
https://www.ebay.com/itm/224893885947
QP7 (10-11-2023)
  #54
Old 10-11-2023 | 01:57 AM
OzXFR's Avatar
They should fit perfectly well.
On another thread around here somewhere (there are multiple threads in multiple sub-forums covering several late JLR models about these alu pipes) EuroAmp have stated that they had a batch of poorly machined / defective pipes but those are all gone now and the latest/current pipes have no problems.
The following 2 users liked this post by OzXFR:
Meanmugga (10-11-2023), QP7 (10-11-2023)
  #55
Old 10-11-2023 | 03:21 AM
dangoesfast's Avatar
Only way to be certain is to ask EuroAmp.
  #56
Old 10-11-2023 | 03:51 AM
Meanmugga's Avatar
Definitely reassuring. Thanks
  #57
Old 10-12-2023 | 01:28 PM
FlipJag's Avatar
Default alunimun coolant pipes
Have had the plastic coolant pipes replaced on both 2015 F-Type & XJ with supercharged 8 banger with aluminum pipes with zero fit issues . Supercharger not removed on either installation .
Meanmugga (10-12-2023)
  #58
Old 10-12-2023 | 01:40 PM
Meanmugga's Avatar
While we're here, what brand water pump is recommended? I think I will do that as well. Since things will already be apart.
  #59
Old 10-12-2023 | 01:47 PM
They have the rear crossover in metal for the V8? If so, link please.
  #60
Old 10-12-2023 | 07:23 PM
pologuy's Avatar
Did they ever change the plastic pipes, etc. to metal in the later years 2018-2019...?
Quick Reply: Aluminum Replacement for OEM Plastic Coolant Pipes
