Aluminum Replacement for OEM Plastic Coolant Pipes
#82
I like Bigg Will's detailed threads? Good pictures and many part numbers listed.
He had an XFR but the 5.0L SC is the same across the Jaguar lineup.
This is one good thread.
Water Pump Replacement
Another detailed thread.
Water Pump and Other
#83
Took me way longer than I wanted.. but got it done 😤
Leak was worse than I thought
Used a loaner serpentine tool to pry it up... made this part a breeze. This helped out tremendously. Its soft and doesn't damage anything.
I noticed a slight pooling afterwards.. where the 2 pieces mate. I seem to have stopped. Drove 6 hrs after and she ran like butter. Coolant levels didn't drop at all.
#85
#89
Meanmugga (10-21-2023)
#90
I wasn't until years later with the XFR long gone I discovered you can get a simple tool for cheap which makes this a piece of cake: https://www.ebay.com/itm/22365759122...3ABFBMpNHQkOpi
Well worth it if/when you want to remove the wipers.
#91
#93
I posted in the F type thread, but I'll be dropping my XJ off at the shop on Monday to do both Y pipe and upper pipe from EuroAmp.
My valve cover stud on passenger bank is spinning freely, which may or may not explain my quart loss over 3500 miles. Replacing both covers just in case.
Hopefully ensures my life as I'm at 90k miles now.
#94
dmchao (11-29-2023)
#95
It's good advice. Unfortunately I'm an unlucky man. I changed my PCV with supercharger on 2 weeks ago, before I noticed my stud was now loose. So, those refreshed parts will carry over to the new covers/seals/grommets.
Shop will also do the injector seal kits x8 and replace the oil cooler/seals as well. Might find some more stuff later.
I changed my supercharger oil last year as well as the rear coolant manifold. Efficiency has not been my friend.
#96
Just bought the RKX kit for my XJ 5.0 SC Will see what it is like when it arrives!
https://www.rkxtech.com/products/rkx...44378830045483
QP7 (01-20-2024)
#100
I'm curious but also wary of some of these parts. The parts from EuroAmp on the Y pipe and lower coolant pipe look good enough, cast and machined with no burring or seal issues.
The rear pipe is a liiitle bit different and uses face seals which are less forgiving than o rings if any tolerances are out far enough.
