Aluminum Replacement for OEM Plastic Coolant Pipes
#141
#142
Since the SC's job is to create and hold pressure, wouldn't it seem like a major engineering miss for it to leak? The other systems you've referenced are not made for building pressure, and if your engine's cylinders were "venting pressure" this would result in low or no compression. A supercharger is designed to operate at pressure, that's what it does..
#143
I concur. however, in my jumping down of rabbit holes, learned that the reason S/C oil is what it is, is that it has a very small expansion coefficient as compared to "normal" engine oils. its not rated in "weight" but has a viscocity of 54 cst. this equates to a 20w oil at 50*C. considering these are being used in sealed systems, thats why. overfilling or excessive weight spec would expand and blow out the seals.
more nerding via Google : What is the Centistoke rating?
The other unit is the Centistoke (cSt) which is used to report the kinematic viscosity of motor oil at high temperatures. The number reflects the time required for a fixed amount of fluid to flow through a certain sized orifice on the testing device.
What is the cSt rating of oil?
In order to claim a viscosity grade , the oil must meet all viscosity test requirements which define that grade. One test used to define the viscosity of engine oil is its kinematic viscosity at 100°C measured in mm2/s or centistokes (cSt). The standard for a 5W-30, for example, is 9.3 to 12.5 cSt.
When I drained the fluid in our RRS, it was about half the expected amount as well. That maybe a sign that these units need a vent.
#144
There's got to be a good amount of air in the supercharger. I would think that the range of temp from dead of winter to full operating temp in summer would make quite a big pressure change.
#145
#146
Are you claiming to know better than Jag and Eaton's engineering teams, or are you just being a douche?
#147
I'm trying to find out the correct procedure for when I do this job in a month or so as there are two schools of thought on replacement oil volume, but I keep running into roadblocks like you.
Clearly, not everything is engineered well with these superchargers or we wouldn’t be replacing the isolators so often. Mine failed in 25k miles. Do you think the water pumps on these cars and the plastic pipes were well designed??
If people are losing supercharger oil, it makes sense there is something wrong with the design.
Any more douche statements?
#148
I already made it clear what I was saying. Pay attention.
You made it to my ignore list months ago, I wish this forum didn't have a "show post" link. I made the mistake of thinking you might have something valuable to say on this particular topic but I guess I'm wrong about everything today.
#149
I'm not saying the oil isn't going anywhere, I'M ASKING WHERE IT WENT. Nobody seems to have any idea. Wild assumptions and guesses with no evidence might be good enough for you, but not me.
#150
From my experience with various blowers over the years? It matches what was posted here. I have ALWAYS drained less oil out then what I put back in. So ALL SC's do use oil. Now how and why is a matter of debate but I have way too much actual experience to worry about the causes?
I just know that I will be taking out less fluid than I will be putting back in. So far that's been the case on every SC I have worked on. It would be interesting to see if the different blowers use differing amounts of oil but again it just does not matter? I change the SC oil based on mileage or if I happen to take the blower off for some reason.
I do wish Eaton had made the TVS blowers with an easier to access drain/fill port. The old M112 was breeze compared to these!
I also admire the few folks who have managed to change the oil with the SC in place! That's a step too far for me and I will take the SC off to do the oil change.
BUT it is possible and at first I did not think it was!
dangoesfast (02-09-2024)
#151
#152
I just know that I will be taking out less fluid than I will be putting back in. nge the oil with the SC in place! That's a step too far for me and I will take the SC off to do the oil change.
I have some experience with "blowers", but it's not in the automotive world. I spent most of my adult life in the precision optics world, working with vacuum chambers of varying sizes. A number of out larger vacuum chambers not only used a "rotary piston" vacuum pump, to evacuate the chamber, but these pumps were assisted by a "roots type" blower, which was located inline, between the chamber and the mechanical vacuum pump. In this application, it's a blower being used in the reverse direction.
Either way, both the vacuum chamber, as well as the auto engine, have the blower creating a "suction", therefore the internal vanes' shafts have seals, which, can allow a limited amount of "seepage" of their gear box's oil, into the intake stream. The blowers I worked with are significantly larger that an automotive unit, therefore the real estate is available for oil level sight glasses, as well as fill and drain ports, for maintenance purposes. However, the operation is quite similar to the car's unit, and yes, oil levels had to be monitored.
Below is one of the pumps that I worked with. As you can see, the blower is pretty large...
#153
I would venture to say that there's a possibility that s/c oil could be sucked through the bearings at that gearcase end. the same burnt/orange stain was around the outside of the casing as it met the blower housing. So, burn-off, evap/weep thru case seals and sucked thru bearings are my guesses, dont see it warping into another dimension or alternate universe.
#154
Received 3,266 Likes
I reckon a fair bit of the SC oil is left behind after sucking out as much of the old oil as you can, a bit like how mucho engine oil is left behind in the engine oil galleries after dumping or sucking out the old oil (about 1.5 litres in the AJ133 and AJ126). For the Eaton TVS SCs on our Jags I reckon some is left behind down low like in an engine sump (dunno if there is any actual sump on an Eaton TVS) and some is left coating the various moving parts of the drive mechanism.
I have searched the interwebz for a schematic or photo of the inner workings of where the oil goes in a TVS SC but no luck!
#156
I am also having trouble finding an exploded diagram or similar, but here's a few resources that show the internals:
https://www.audizine.com/forum/showt...slight-porting
https://superchargersonline.com/2011...arger-coupler/
#157
The other day I noticed some whiter smoke than usual at idle from my exhaust. I can't smell coolant, but I let it cold soak and it looks like I may be losing just a hair. I had my water pump replaced at the same time as my coolant piipes with the aluminum Y pipe and front crossover from EuroAmp, so hopefully just a minor issue with the water pump/OEM solutions. I notice a little seepage under the pump, but the shop who did the work did pressure test.
I'll call and book in a week or two when I have some time, and keep monitoring for now.
#158
Well, here's a question and apologies if it has been addressed before.
Isn't it true that replacing the plastic pipes with metal pipes is only half that battle in that don't we have crappy spring clamps all over the coolant system? Wouldn't the gold standard to make sure these new pipes get connected with screw clamps or is there anything even better? Why oh why did they design it so crap when the car is so good?? Ugh. Am I being harsh? I mean 7 attempts on the water pump? Now modern Mercedes are no better (planned obsolescence) but the later MY W140's were not like this. But, on the other hand no where near as dynamic a car...
#159
Re
Spring clamps are not worse than screw clamps for cooling applications. They’re the gold standard in automotive for cost and quality, as they apply constant force. It’s not so much for us as it is the factory. Build 900 vehicles a day and a few ft lbs variance will kill your product quality.
lotusespritse (02-16-2024)
#160
