XJ ( X351 ) 2009 - 2019
Ambient
Old 09-17-2022, 09:07 AM
gloriashield's Avatar
Thumbs up Ambient
Hi guys,
It's ambient system bought in aliexpress. It is controlled by LIN, each communicating wirelessly with modules. Very satisfactory quality. It is fully compatible with Jag's system. With Dynamic-i, the red color is very impressive. There is one bug. Level 1 of the 4 levels of brightness adjustment is not available. But it doesn't really care.
Regards,
KIM
The following 2 users liked this post by gloriashield:
Clovis997 (01-28-2023), George05 (09-17-2022)
Old 09-17-2022, 04:09 PM
George05's Avatar
I like it , is it easy to install ? and do you have a link please
Old 09-19-2022, 12:42 AM
I didn't think it was difficult for me. Of course, it varies from person to person. Pre-FL models need to be controlled by a mobile phone. CCF modification is required for use in ICTP. I worked on the front door one day, the rear door one day, and the air vent one day. total 4 days. my seller' is sold out. It is other seller's.
https://aliexpress.com/item/1005001527196178.html
Old 09-19-2022, 01:58 PM
George05's Avatar
Thanks but will pass on this , £500 is a bit much for a couple of lights
Old 12-17-2022, 11:07 PM
XJunkie's Avatar
Hey glo I just bought a set of the vents did you have to remove the air vents completely in order to install?
Old 12-18-2022, 12:20 AM
Yes, you have to remove all vents. look this.
My friend made handmade tool like jaguar's for made vents easier to remove.
Old 12-18-2022, 01:14 AM
XJunkie's Avatar
What about the wiring? Did each vent come with a control module? Mines didn't just a bunch of wires... do I Daisy chain them together?
Old 12-18-2022, 09:28 PM
Here is my blog with ambient post. Since it's posted in Korean, please use Chrome's translation. I think it will be helpful for you.
- https://grip.news/archives/2379
Old 12-19-2022, 03:45 AM
XJunkie's Avatar
Thank you!! Thank you!! thank you!!!! That helped alot & answered many questions.... u saved my life Glo!!
Old 01-18-2023, 09:49 PM
XJunkie's Avatar
Finished a lil project... experiment turned out pretty good!!!
Thanks again glo probably wouldn't have figured the vents out without u!!!
The following 2 users liked this post by XJunkie:
dmchao (01-29-2023), XJ8JR (01-20-2023)
Old 01-20-2023, 09:59 AM
XJ8JR's Avatar
What's the story with that smaller AC screen you've got underneath the main display?
Old 01-20-2023, 02:56 PM
XJunkie's Avatar
What do you want to know about the ac screen?
Old 01-22-2023, 03:58 AM
Geoffrey Fake's Avatar
i like the led on the doors and upper front dash any tutorial?
is it difficult to install ? where can I buy that ?
thank you
Old 01-22-2023, 03:45 PM
XJunkie's Avatar
Thanks it's not really difficult to install although it's tedious & time consuming took me about a week to finish... you have to figure out the limitations of the strips in order to do a successful install.. in a post above by gloriashield is an included link which describes some of what's involved... I used his write up to install the vents... I used a different process with the doors but similar to his because we used different products.. his is made specifically the vehicle mines is a universal kit...
But I got the kit from a supplier on alibaba... they also sell them on aliexpress. Not really expensive but cost can add up depending on which look you going for... I used 2 kits & alot of extra strips because you are going to make mistakes & will need extras...
I used 2 strip kits & the vent kit plus the extra strips cost me around $600-700.. which isn't too bad for the end result looks like a 2023 s-class on the inside... im very happy with it!!
I can do a write up of what was done & provide pics of the process if yall want me too & if u have any questions I will glady answer them for anybody
Old 01-22-2023, 07:58 PM
XJunkie's Avatar
I used a 22-in-1 kit & custom sized 18-in-1 kit plus the extra strips.. plus the air vent kit... if you want to do the seats like I did you will have to order some extra control modules...
There are different types of kits for different prices. The kits i used are a universal the kit gloriashield used was vehicle specific... they are wired & controlled differently, also the color changes are different... the vehicle specific kits are mainly RGB led types & change 64 colors.. the universals you can buy RGB or symphony color change which has alot of special effects & patterns.. I used the symphony kits
the universals can be controlled using a APP, button, voice activated.
The vehicle specific kits can be controlled using APP, Reaview mirror, steering wheel, button, OEM ambient light controls (newer cars)
wit the universal kits you can do alot more IMHO & installation is more flexible with being able to add more strips if needed & not needing to do complicated wiring
The vents are a completely separate kit which are really used with the vehicle specific kits & are normally bought together, which only does RGB color change..
i puchased them alone & they are not compatible with the universal kits so they must be controlled independently of the rest of the lights if being used with the universal kit & again they only do RGB color change....so you will need 2 different APPs to control both... you could possibly wire them together in order to get em to all switch together... thats what i was going to originally do.. but changed my mind because I bought some light rings to install in the lil mid range speakers on the door inside the wood trim but when I tried wiring it together wit the strips & sub modules I burnt the rings out & did want to risk doing the same thing with the vents.. which were not cheap at $250 the rings were only $75 so I could stand that blunder..
Old 01-22-2023, 11:51 PM
XJunkie's Avatar
Symphony light modes are supposed to have 200+ different effects & can flash & dance to the music
Old 01-23-2023, 10:29 AM
XJ8JR's Avatar
Everything. Where did it come from and how did you install it? I've never seen that in any XJ
Old 01-23-2023, 02:01 PM
XJunkie's Avatar
I got the ac unit off of alibaba for about $350.. fully touchscreen works great & is easy to install completelyplug & play, jus remove the old unit... it updates the vehicle a bunch inside, especially when combined wit the big screens looks 2020ish... but you will lose the use of your cd/dvd player when installed.. but it is worth the money.. im happy with it
Old 01-24-2023, 10:09 AM
XJ8JR's Avatar
Interesting. Could you provide a link to the seller you bought from? Could you show us a bit more of what it looks like installed?
Old 01-24-2023, 11:47 AM
EliteZags's Avatar
you're calling it plug and play, the other thread on here makes it look/sound like a complete nightmare to deal with to just replace the 10in screen (I wouldn't consider gutting out the entire center console and extensive CCF parameter programming to be "plug and play")
https://www.jaguarforums.com/forum/x...pgrade-227763/
or is the one you're using that much easier to install somehow?
I've seen them from several sellers all around same price AliExpress unit
just don't see how those would be any different installation than the other thread
Quick Reply: Ambient
