Any one still having issues with the roof popping noise?
I had the software update and roof fix done last week and everything is fine. I'm glad the noise is gone because it was somewhat embarrassing - it was pretty loud. The voice control is nice, and we finally have the ability to enter a nav destination while driving. Now if I can only figure out how the TMC works...
When you guys talk about "roof popping" noise, do you refere to a noise opening and closing the sunroof? Or just a log of creacking in the roof headliner.
Eventhough my dealer did the "sunroof bracket fix bulleting" I got a LOT of noise in the roof. But ONLY when it is cold. Here in Chicago the winter weahter started and the noise in the roof sounds like somethig will crak away any moment. Stops after the interior warms up. Probably just the roof liner. Anyone else has a similar issue?
I will bring back to dealer as I also noted one of the little lights in a door handle is not working (actually is is not even there).
The roof popping noise most of us are referring to is a problem with the way the glass roof is attached to the car and the sound generally is toward the rear when you go over bumps in the road or make sharp turns up or down an incline--it does not have anything to do with the sun roof operation. It was very annoying, but my dealer finally got it fixed based on instructions and replacement parts from Jaguar. It does not make any noise now no matter what the road conditions or ambient temperature are--it is possible to fix this if your dealer knows what they are doing, but this is a big problem because some dealers just need to call it quits!
#28
All is fixed now. After the initial bracket TSB which was done before I took delivery, I was worried as I still had noise.
Mostly when cold and when car body is "bumped" or "twisted". The service techs needed some time to find it, but they took all the time needed and did a minor sunroof adjustment and some minor headliner adjustments.
I wasn't too confident at first.. but guess what. ALL noises are GONE. No matter if hot or cold weather. I hope that was it. All of you....a good tech can fix it it seems. Good luck.
Darn, its back!
No, not anything in the headliner, not any squeaking, a popping (like a seem or rivet point) if car hits bump or ist twisted on curb.
Anybody any idea???
Been at the dealer. First they can't even hear the noise. Then they said they found something. The "sunroof pop fix" is done. I made sure there are no noises from the sunroof liner.
I love the car and don't want to get rid of it. I am a restless (and believe talented) tinkerer. I know the dealer mechanics won't take that time and dedication EXCEPT I raise a major stink. I want the noise gone. ANYBODY? Any Ideas.
Anybody any idea???
innzane
09-02-2015 10:08 AM
