to anyone who has the light dimming option : please picture !
hi there,
can anyone that has the light dimming function option on their XJ ( eg, the lights are full on at night, a car comes from the front, the XJ automatically dimms the lights ) can :
- post a photo of the stalk ? cna you see AUTO written on it ?
- post a photo the the front glass ? to see where the sensor is ?
thank you !!!!
thank you !!!!
Goncalo Proenca (08-28-2015)
The sensor is the white square in this picture, in the back of the rear view mirror facing the front of the car:
![](https://www.jaguarforums.com/forum/attachments/xf-xfr-x250-44/18369d1333679881-whats-sensor-forward-side-auto-dimming-mirror-1-2012-04-05-21.13.44.jpg)
See the Owner's Handbook for pictures of the headlight control stalk and operating instructions: JJM 10 02 34 141 - XJ Owner's Handbook | TOPIx
If this was helpful, please press
at the bottom right.
Stuart
![](https://www.jaguarforums.com/forum/images/kirsch/buttons/post_thanks.gif)
Stuart
AUTO HIGH BEAM
This feature automatically selects and
deselects high beam, under specific conditions
of road lighting and in the absence of other
vehicle’s lights. The system is only active when
the ambient light drops below a predetermined
level.
This function is only active if the lighting switch
is in the AUTO position and the stalk is in the
central position.
The system will only activate when vehicle
speed exceeds 25 mph (40 km/h). The system
will deactivate when vehicle speed drops below
15 mph (24 km/h).
Note: Auto high beam does not operate when
reverse gear is selected.
To manually select high beam, move the stalk
to the high beam position as normal. To return
to Auto high beam, move the stalk back to the
central position.
To manually override to low beam from high
beam, pull the stalk to the flash position and
auto high beam will be cancelled. To return to
auto high beam, push the stalk to the high
beam position, and then return it to the central
position.
Daylight running lamps can be
enabled/disabled by your
Dealer/Authorized Repairer.
When auto high beam is enabled,
the system indicator will
illuminate.
level.
central position.
15 mph (24 km/h).
central position.
position.
illuminate.
See my earlier thread "Before You Ask For Help" and the link to the step-by-step video about how to use the setup menu. Select "High Beam Assist" and make sure ON is checked.
Stuart
I have that white square on my rear view mirror, but cannot set the HBA from the settings. I talked with our Jaguar dealer and he said that if the option was not originally installed, then it's not an option on my car - regardless of the mirror's design. Same mirror, some cars have HBA and some don't. Kinda makes me wonder if there's a software download that would enable this option.
All dealers tell the same, look on my mods they are impossible to make according dealers speaking
'Cause manufacturer policy has a lot if restriction: "if you want something more - buy new car", so in general even the dealers can't make a lot of mods or shut down some options
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
ronald4313jm (09-08-2015)
pretty much : no
they said they would do it, the problem is that Jaguar UK does not relase to them the codes needed to update the eletronics to "know" that they now have AHB dimming.
To clarify : the light dimming option is NOT the white square on the mirror - that is for the mirror dimming. It is the bulk sensor on the mirror - my mirror support hanging thing its not that bulky, ie, does not have the sensor.
KarimPA
09-12-2015 08:15 AM
Jaguar Forums Editor
Jaguar Press release
09-04-2015 09:18 AM
09-03-2015 09:38 AM
