Armrest open button stucks
Exactly whay mine does. No i haven't because i was hopping somebody will provide with instructions from workshop manual to get solved without any damages, but no luck. So i will visit some garage to repair it. As i know it is mostly common thing on X351 as poping sunroof.
pellowe (02-17-2016)
I hate the idea of putting a lubricant into the button slot but as have nothing to lose tried some silicon spray which didn't help. So tried a little bit of white spirit on a sponge, dripped it in and I must say the button is returning faster and is acceptable for me now. Hope this helps.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Dwayne
I have managed to fix my sticking centre console button. I took the whole thing apart and noticed there was a build up of grease in the groove where the button pushes down. I have put together a document of what I did so hope this helps solve your problem if similar to mine.
Thanks for the instructions. I did this today. Cleaning the grease didn't work, but adding new grease made all the difference. I assume it'll get dirty again, but at least for now it works like new.
Also, the trim removal is just nasty on this car. Several clips broke off in place, and I added a slight crack to a trim piece.
The armrest lid not latching is an easy fix in less than a minute. It is not necessary to replace the entire armrest assembly or disassemble anything. You just need to know what to look for. Most importantly, do not spray any lubricant into the mechanism, as it will attract dust and dirt that is the cause of the problem.
For details, see my 2017 thread:
https://www.jaguarforums.com/forum/x...-fixed-177536/
daz440
02-24-2016 06:10 PM
Clutch9801
02-16-2016 08:56 AM
car5car
02-13-2016 08:48 AM
