XJ ( X351 ) 2009 - 2019
Auxiliary Battery
Old 11-13-2019 | 11:54 AM
Nightshadow's Avatar
Default Auxiliary Battery
Hey guys - quick question. On the 2013 Jaguar XJL, I had the auxiliary battery replaced recently and am being told by the mechanic that it seems to be reporting or charging at 10 volts vs 12v. Is this normal on a brand new battery? If not, what could be causing this issue?
Old 11-13-2019 | 12:26 PM
Mark SF's Avatar
If it's genuinely reading 10V after charging, it has a dead cell and is faulty. Mine was the same, but that was 5 years old.
Old 11-13-2019 | 12:28 PM
That's what I figured - doesn't make sense that it wouldn't charge properly.
Old 11-13-2019 | 09:56 PM
pologuy's Avatar
Not to hijack your thread...but...
Anyone know why they got rid of the auxiliary battery in the latest XJ models?
And what they "replaced" it with...?
Old 11-14-2019 | 09:28 AM
XJsss's Avatar
Capacitors in the same place as the secondary battery.
The following 2 users liked this post by XJsss:
Nightshadow (11-14-2019), wombat (09-14-2022)
Old 11-14-2019 | 10:36 AM
Brutal's Avatar
This is why i just told someone in another thread to unhook the battery. Unless you just love the eco system. You have a bad new battery because many times when i get these there is a fualt in the system ie... Gate way module(GWM) needs software update, 1 if the 2 battary contacters(fuses) are bad in the module under the aux battery(replacement of the whole unit) and then depending on year and faults replacement of the dual battery charge module. Fancy new fangled stuff throws so many uneducated mechanics on the systems for loops.....
Matt Cox (09-20-2020)
Old 03-28-2022 | 10:10 AM
ecamiel's Avatar
Default 2013 aux battery
Is there any replacement for the Exide Starter Battery Start-Stop Auxiliary EK151 available in the USA? I know you can order them from Europe but with shipping it is expensive.
Nightshadow (03-28-2022)
Old 03-28-2022 | 11:19 AM
Honestly I don't know but my mechanic just replaced it with a similar battery used for like tractors or ATVs or whatever, he found one that was swappable and it worked fine. Never had issues after that.
Old 03-28-2022 | 11:37 AM
ecamiel's Avatar
Default Aux battery XJ 2013
What tractor or ATV battery did your mechanic replace it with? Brand and model please. Did he have to change the battery terminals?
Old 03-28-2022 | 12:16 PM
Iowa4576's Avatar
I bought an Excide replacement battery that was advertised on Ebay. It is the EK151 shipped from Latvia.. Shipping was not expensive and the battery arrived in a few days. Here's the Ebay link.https://www.ebay.com/itm/15287241381...3ABFBMgpGKlfpf
Old 03-28-2022 | 12:23 PM
ecamiel's Avatar
Default Aux batt XJ
I tried that and today it comes to almost $190 with shipping
Old 05-24-2022 | 10:31 AM
leaddog11's Avatar
I agree. I unhooked mine. Dont need or want the eco . Dont want the extra wear and tear on the starting system plus dont want my ac cutting off.
Old 09-14-2022 | 06:18 PM
Kbschicago's Avatar
why are people opposed to the eco start/stop feature? XJL Portfolio
Old 09-14-2022 | 08:36 PM
Addicted2boost's Avatar
Kbschicago, that battery is made just for JLR and that little guy will cost you a fortune. If you like the start/stop feature, then get the battery replaced. Don’t let everyone else tell you what you should or shouldn’t have in your car.
Old 09-15-2022 | 07:49 AM
leaddog11's Avatar
Exactly. I totally agree.
Old 09-15-2022 | 07:51 AM
leaddog11's Avatar
Yep
Old 09-15-2022 | 11:52 AM
Kbschicago's Avatar
When you say the little guy will cost me a fortune are you referring to the cost of the battery or problems and fixes due to using the start/stop?
Old 09-15-2022 | 11:55 AM
Kbschicago's Avatar
also, if it is made just for the JLR then why is it in my XJL Portfolio? I'm not sure I want the start/stop or not.
Old 09-15-2022 | 06:24 PM
Freddy J's Avatar
Nightshadow, further details If you don't want the Stop/Start feature: make sure you disconnect the ground cable going from the small battery to the chassis/body not the red positive cable on the battery. If you want to be able to reconnect it quickly for warranty or visits to the dealer, you can do what I did and put a battery switch on the black cable where it grounds to the body.
Old 01-02-2023 | 12:24 PM
ecamiel's Avatar
Default Aux battery disconnect
I would happily disconnect the Aux Battery from my 2013 XJ Portfolio. Replacements seem impossibly expensive unless someone has come up with a cheap substitute?
How do I get rid of the dashboard warning light for that battery and the Aux start system if I do disconnect it?
Eric
Quick Reply: Auxiliary Battery
