battery change for key fob
Item C should be the screw you are looking for.
The following 3 users liked this post by GGG:
Thanks GGG... This diagram is nice and concise... My problem was on step "B"... I found the slot req'd a 0.5mm tip screwdriver. Most notworthy is the fact that the screwdriver should be leveraged down (as shown in "B")... Twisting the screwdriver chewed up the opening slot a little on my first attempt... Live & learn... a picture IS worth a thousand words all right... Thx Kyd
Yes it's tricky! I just changed the battery myself. Step (A) should be at a 30-deg angle and a gentle push forward. Step (B) should be 90-deg, push the screwdriver straight down with force until you feel a pop, only then do you angle it down as indicated in the diagram to separate the clamshell.
