XJ ( X351 ) 2009 - 2019
Battery charger question
Old 10-11-2020 | 10:04 AM
michaelnv's Avatar
Default Battery charger question
2015MY Is it ok to hook up a trickle charger on my main battery without disconnecting the cables?
I haven't been using the car and getting the low battery warning.
Old 10-11-2020 | 12:07 PM
Tony R's Avatar
Hi
I have a XJ (2017) and use a CTEK automatic charger and charge the battery while the cables are connected but ensure :
1. The black charger lead is connected to the bodywork ( not the battery ) I use one of the protruding bolt heads
2. The red charging lead to the battery
3. After switching off the mains power disconnect the black charger lead first
I have read that this method of connection will not interfere with the Battery Management System
Tony
michaelnv (10-12-2020)
Old 10-11-2020 | 01:18 PM
roviw's Avatar
I have used ctek charger/conditioners for 10 years now, they really keep the battery in top condition. If you fit the quick connector lead it is a 10 second job to connect it up each time.
As mentioned above the red lead goes to the positive terminal and the black lead goes to a ground bolt near the battery.
The following 2 users liked this post by roviw:
michaelnv (10-12-2020), Tony R (10-11-2020)
bocatrip
10-23-2024 06:40 PM
UltraPeepi
01-26-2024 01:35 PM
worrasf
07-28-2020 03:53 PM
ek993
01-07-2018 07:19 PM
06-XJR
16
07-05-2016 11:13 AM
Quick Reply: Battery charger question
