battery replace
battery replace
Hi all.
Can someone tell me exactly which battery I need to put on my 2010 jaguar xj?
I don't have start- stop on my car and in the trunk I have only 1 battery. (Not 2, the little one not exist) do I need an AGM battery?
I saw in 2014 xj a 12v 90ah 850A AGM battery. (But in this car he has a second little battery as well and start -stop.
So someone can please tell me what exactly do I need?
Received 3,209 Likes
You need a different charging profile to get any benefit from AGM. If the car doesn’t have AGM now, charging is set up for flooded, and an AGM would likely have a SHORTER life due to being undercharged.
Bedt rule of thumb is always replace like for like. You need an ordinary flooded battery.
IMHO All x351 Xjs are equipped with AGM batteries from the factory. As a matter of fact my dealer only stocks AGM batteries for the XJ as the electrical system is verty demanding. A CTEK charger is great for prolonging life and deep recycling when needed. Here is what I have:
Your needs may be different, but this works for me
QP7 (10-10-2023)
This is the battery listed in the Jaguar parts catalog for the OPs model year. I think this is not AGM :
https://www.jaguarparts.com/oem-part...bC12OC1nYXM%3D
While for vehicles with stop / start, it lists this. This one states AGM :
https://www.jaguarparts.com/oem-part...LXY2LWZsZXg%3D
So my assertion is that vehicles without stop/start use a conventional flooded, while if you have stop/start, AGM is required.
I have a 2012 s/c 5.0, and it had an AGM. I replaced with a flooded lead/acid 3 or 4 years ago, and it has been fine, even in ten below Chicago area starts. I do get the occasional "low battery" alarm, but it has never failed me. At the TIME, lead/acid was appreciably more expensive locally, and places like Rock Auto did not carry them, but now they do, since they CAN be shipped commercially, where wet batteries could not. Not sure where you are or what the availability of each is, but you may find the price difference is not that great, and the AGM is just a better battery.
