Battery Replacement
lotusespritse (03-16-2024)
The following 2 users liked this post by doomtrain:
Ken Dreger (03-03-2024),
NavyBlue (02-28-2024)
I use the H8 battery from Walmart. Good value and massive distribution so easy warranty if needed.
My stock battery lasted 10+ years so I am lucky.
Walmart H8 Battery
One thing to check is the warranty as most give you 3 years but that Walmart one gives you 4 years.
Walmart H8 Battery
The following 2 users liked this post by clubairth1:
NavyBlue (02-28-2024),
tergitkerd (03-01-2024)
The last one I bought was actually 4 years ago today.
From Costco, an Interstate Battery H8 AGM type 49 for $179 + tax without the $15 core charge since I handed them the old battery when I picked it up.
No problems yet, of course the temperamental battery monitor gets cranky if the doors are open for an extended period, but it always has & always will with the 2012 software.
NavyBlue (02-29-2024)
The following 2 users liked this post by IanXF:
NavyBlue (03-01-2024)
Yes my Walmart has a service center so easy and convient. I don't allow anyone to touch my car now that it's out of warranty. A battery replacement is dead easy BUT I use any service work to inspect the car and try to stay ahead of additional problems. Plus will they clean the battery terminals if they are corroded with baking soda? No it's just a remove and replace regardless.
Plus what I have learned on this forum causes me to ALWAYS charge ANY battery BEFORE it's installed in my car. I never did that in the past but as picky as Jaguars are about batteries and their level of charge it's just cheap insurance! I still can't believe how big a deal batteries are to these cars!!
The following 3 users liked this post by clubairth1:
I bought mine a few years ago from Sam's Club, they did not install it however. Duracell H8 AGM 850 CCA, 3 yr warranty. Make sure it is an AGM battery, it is more expensive than a standard battery but more suitable for the use expected. Also I have not noticed any corrosion on any of the AGM batteries that have been installed past or present on this car. Since the battery is in the trunk under a flooring a standard battery would likely have corrosion and be a bigger risk of damage.
My Jag mechanic recommends the same battery.
Cheaper replacement battery
I installed a Weize Platinum AGM battery this morning. I purchased this online from Walmart.com for $149.99 + tax, free delivery. I suspect this is the cheapest battery available on the market. Here are the specifics:
Group 49, H8
900 CCA, 160 RC, 95AH
36 month warranty
Before installation I connected this new Weize battery to my battery charger and let it get to a full charge. Installation on the XJ is a bit more complicated than your standard car. I used another 12V battery to connect to the car through the jumpstart ports. Doing this meant the computer was always powered while the main battery was replaced, all previous radio/seat position/mirror position/trip computer and engine/idle settings remain.
The auto-start-stop feature, which everyone seems to hate, started working immediately after this installation after having not worked for the past 4 months, indicating that my prior battery had indeed gone bad after just under 5 years.
Also I found a better work around for the auto-start/stop battery instead of paying the dealer over $400. Using a YTX-14 BS AGM ATV/Motorcycle battery which I bought on Amazon.com for $42.99 +tax I then connected them with 4 gauge 1 foot cables which I bought for $9.99 +tax
Group 49, H8
36 month warranty
NavyBlue (03-28-2024)
