Battery Tender
scottjr1 (01-16-2018)
I have both, and the answer is "No" for both. The cigarette lighter is switched, which means that that circuit is closed and has power only when the ignition is on. When the ignition is off, that circuit is open and electricity can't flow to an accessory.
Here's how I hooked up my CTEK battery maintainer to my XJ. Caution: never attach the negative lead of the maintainer to the negative battery terminal; always attach it to a chassis ground.
https://www.jaguarforums.com/forum/x...ion-130801/://
TreVoRTasmin
08-18-2020 09:21 PM
