Brake Dust
ExpatJag (06-18-2011)
Let me give another vote for the Armor all wheel treatment--the stuff in the tall thin can.
The wheels were filthy with brake dust after just 150 miles of regular driving, but after following the directions TO A "T", my wheels have been shinier-than-new with ZERO brake dust. Good stuff. No brake dust even after driving in the rain the other day.
You haven't seen the worst brake dust problem unless you've owned a BMW. The wheels turn black after a couple of days of driving. I use a power washer on the tires (it doesn't take off the silicone tire coating just the dust) and wheels every few days. If I'm in a rush, I just drive off and let the water spin off the wheels.
I'd highly recommend against dust shields. They significantly reduce the airflow to the brake discs and trap the heat, which may cause the discs to warp resulting in shimmering during braking. It can be costly to resurface or replace the discs. Some manufacturers will even invalidate the warranty on the brake assembly if you put the shields on.
Do you wax your wheels?
You will significantly lower the brake dust buildup if you do.
My double fives used to turn ash-like maybe 3 days after a wash without wax. Now when I was the car I use a foaming alloy cleaner (I recommend Turtle wax or eagle, you want the heavy duty corrosive ones (with the symbol of a hand turning into bone)), spray it on, scrub with a brush, and wash off with a garden hose (do this relatively quickly, don't leave the foam on for more than maybe 2 minutes or so). If there is a specific spot that you're having trouble with you can use a scotch brite sponge lightly, soaked in the alloy cleaner, then again rinse with water. Then, apply wax on the wheel - I use a turtle wax green wax paste with a sponge applicator. Let it dry for a few minutes, polish with a microfibre.
With waxing my wheels now look spotless like new between washes, as opposed to days.
I have found the stuff!
A friend gave me a can of the new Armor All Wheel Protectant.
It works! I have used it two times. The first time I did it my way and it sucked. The second time I did it just like it said on the can. It has been 8 days and the wheels look great! 300 miles. Even the fronts. For ArmorAll it is in a different looking can. Slender with a small top. Amazing! Never much used ArmorAll, but will now. Also did the Mini with it but only 3 days ago so more to come. TRY IT! 6 USD.
xjrjag
09-24-2015 10:08 PM
