The center glovebox won’t close
Hey guys, i think i have the devil in this car, so many problems. My center glovebox wont close, anybody had this problem ? Anybody knows if i have to change all of it or the pin can be sold seperatly at jaguar ?
Eventually how tonopen and repair
Thanks to all
Thanks to all
It's an easy DIY fix. Here's how to do it. See my 2/28/2017 thread: https://www.jaguarforums.com/forum/x...-fixed-177536/
P.S. Don't use any lubricant, as dust will stick to it and will cause the latch to get stuck again. Use a can of compressed air similar to this:
Read your CPO warranty terms snd conditions and exclusions. If you do not have that complete document, ask your dealer to provide you with a complete copy and to cite the specific language that supports his conclusion that this is a normal wear item.
Without reading that CPO warranty, I find it difficult to equate a latch mechanism with a tire, fan belt, brake pad. radiator hose, or other part usually considered to be a normal wear and tear item.
The CPO contract controls, not the service advisor's opinion.
I should have been more specific when referring to the spring. The spring that goes on the hook/locking mechanism came loose, not the spring on the release push-button.
