Central Mounted Clock
Received 3,928 Likes
Ceckman (03-02-2019)
clubairth, it would be interesting to see if there would be something that would fit into that opening that would also plug into the OBD port. that way, with a little bit of programming, you could display just about any parameter that the computer sees. Could even potentially use it to read OBD codes without having to connect up a separate reader.
The 5.0L V-8 has no place to measure oil pressure. Which is odd. You can measure the volume of oil in the sump real time in Liters.
But somehow it doesn't seem the same?
I have seen these Ngauges before and they sorta look like that.
You can program and changes the sensors monitored too.
qwiketz
Audio/Visual Electronics
08-23-2014 02:45 PM
bhmaxjag
12-13-2010 11:00 PM
T.C.
05-15-2008 09:25 PM
