Ok, for some reason my 11 XJ is now showing C on the temp displays instead of F. Page 60 of the manual #13 (Settings - Heating and Ventilation)) says "Select to alter the sensitivity of the air quality sensor, or to select F or C as a default temperature unit."
My XJ only shows the air quality sensor adjustment slider under settings. There is nothing about changing the temp unit at all.
Is there some kind of hidden button combination I did to make this change?
