XJ ( X351 ) 2009 - 2019
Chasing a front end clunk
Old 05-26-2024 | 01:57 PM
Timothy Geyer's Avatar
Originally Posted by Polyesterpig
Since I purchased this 2011 XJ Base N/A CPO car, there has been a slight clunk over small bumps in the road at low speed. Also, while driving slow, you rock the steering wheel left and right, you can hear the clunk. The clunk is slowly getting louder.
I took it in and had the following replaced.
*Front shocks
*Upper Shock mounts
*Sway bar Bushings
*Sway bar links
*front control links
*upper wishbones complete with bushings and ball joints
*1 engine mount (CPO warranty would only replace one) warranty expired 14 days ago.
*transmission mount
The only things left are the other engine mount, which I am going to do and the lower Ball joints. (but they are tight).
Now I am wondering if it is actually anything to do with the suspension, or is it something structural or steering or? Any suggestions where to look would be great.
Note, every time I take it in and they do an alignment. The clunk seems to go away for a little while, but it slowly returns. It seems after the car was lifted up in the air, it solves the clunk issue for a little while until it settles back down, then it returns. I was hoping they would find it under warranty, but that time is passed.
Hi, did you ever find the problem? Thanks.
afransella
12-15-2021 08:09 AM
Jagzzz
10-26-2015 12:46 PM
SuperTrav
26
12-07-2014 08:06 AM
04xtype04
03-30-2014 06:20 AM
thenaz007
11-17-2011 09:08 AM
Quick Reply: Chasing a front end clunk
