The scuff plates are satin brushed. Mine is scratched up as well.
Just clean them up by re-brushing it again.
Buy one of those 3M green pads. Go with the flow of the brushing lines. You won't get those deep scuffs off. But 80% of them will be gone in 20-30 passes. To get those deep scuffs off, you can try sanding them down with a 200 grit sandpaper and finish it up with the 3M green pads.
Thank you, are you sure this won't scratch them more :-s
Originally Posted by JimC64
They don't look like brushed aluminium to me, but if they are it certainly sounds like a plan.
Sounds like you may be looking to replace them anyway as a last resort?
If so, a general sanding down, perhaps followed by fine grade 0000 wire wool then Autosol metal polish could achieve the desired effect?
Worst case scenario you have to replace them
I'll try the wire wool if the brillo stuff doesn't work.
