XJ ( X351 ) 2009 - 2019
Cold start sputter and black smoke
Old 06-12-2024 | 05:53 AM
jaguarxjl's Avatar
Default Cold start sputter and black smoke
I have a 2013 Jaguar xjl. 3 liter. AWD.
It is 70 degrees here. Not exactly cold weather.
First thing in the morning, the car takes 2 or 3 attempts some times to start or even if it starts in the first attempt, there is a lot of sputtering and black smoke.
I have already replaced both the MAS (with two new Bosch units - OEM was also Bosch).
The problem remains. The car works fine after cold start issues. Some times it takes 2 or 3 attempts to start.
Any suggestions?
Old 06-12-2024 | 10:32 AM
12jagmark's Avatar
I'd expect black smoke on cold start-up would indicate oil getting into the intake or cylinders while at rest.
You'll need to look at it closer to find what the source is.
If you could pull the plugs when it's cold & look into the cylinders with a boroscope, you could see if there is any oil accumulating in a cylinder.
But where ever it's getting into the system, it can damage the catalytic converter for the side it is getting in, assuming that is the problem.
jaguarxjl (06-12-2024)
Old 06-14-2024 | 03:40 PM
Jaaag_drivah's Avatar
Any strong smell of gasoline in the crankcase? Could be an injector leaking down into the cylinder making you run pig rich on a cold start. That would also explain why it takes awhile to start because the HPFP has to rebuild operating pressure.
BruceH
XK120 XK140 XK150
10-08-2021 02:39 PM
SteveP15ftypeR
12-05-2016 11:01 AM
GrahamNashBFJ
03-10-2015 01:11 PM
ratgawd
12-27-2014 01:21 PM
charliepace
12-09-2010 09:10 PM
Quick Reply: Cold start sputter and black smoke
