Which color?
Which color?
We are looking at 2 XJL's, both 2017 and loaded, but are having qualms about the two color choices. One is Santorini black with ebony interior, and the other is Yulong white with oyster interior. I saw a photo of one in rhodium silver which I thought was stunning but may not be so easy to come by. Husband likes the white and I like the black. So it really is a black-and-white issue. Which has the most head-turning appeal? Thanks!
I personally like the black look. But, depending on where you live, this may be a bad color. While I don't live in the hottest of places, it does get warm in my area (summer is normally around 90ish) and the interior of the car will be very hot at first. With the black interior like you are looking at, it is going to get just that much hotter. If you think about sitting in the seats wearing shorts, you will quickly learn that you won't do that a second time. I am "fortunate" in that my car came with a black exterior, but a cream interior. So, if you live up north, the black will get more looks. If you live down south, then the white is the way to go.
I always go with white.
Not sure if this has been disproven, but I was always told, black cars get hotter (they absorb heat easier, whereas white reflects it) and they look filthy when there is just a little bit of dirt on the car.
In my non-scientific research, this seems to bare out. If you don't care about those things, then it won't matter, but the look and temperature of my car are a big deal to me.
lotusespritse (03-17-2024)
I'm not an XJ owner but I do like them so I will offer an opinion.
I agree that silver is a good choice. It looks classy, shows the shape, lasts forever between washes.
I dont like white in pretty much any car although it really is the most practical. It is miles cooler and surprisingly easy to keep clean. It also looks good against black trim. If I was to get a white XJ, I'd be setting it off by dark tint and maybe black wheels. White is also good for resale because it is a "safe" colour.
Black looks much better but is monstrously hard to keep clean unless it has a good amount of sparkle in it. The more metallic sparkle, the easier it is to keep clean, but the less stunning it is.
QP7 (03-05-2024)
Well, just remember, you're going to be in a black car eventually !!
In my experience with a white XJ6 in the late 80s, (and no air-con either), is that a white or light coloured car stays a lot cooler when parked in the sun. So when you get in to drive off it's immediately reasonably comfortable. A black car, on the other hand, is like an oven initially.
Regardless of exterior color, always use a reflective sun shade to protect the leather dashboard from shrinking. And use a thin viscosity leather conditioner that can be absorbed to help preserve your interior.
See my post #3: https://www.jaguarforums.com/forum/x...yellow-170469/
Stuart you bring up a point I wondered about?
It did not completely keep me from getting and XF but everyone knows they suffer from the leather dash peeling up.
But I have never seen or heard of anything like this on a X351 XJ?
Seems like the XJ dash is much larger and has a lot more leather on it too.
While I don't have an issue with the dash leather, I did have ir heat coming through the my windshield after I had to have it replaced due to debris kicked up when I was on a highway as the newer windshield only have uv shielding. So I had Illimar air 80 "tint" installed and it cut out more than 89% of the "heat" coming in, but it is invisible as it's designed to reflect ir and uv. It's so good had it installed on my wifes 2018 Audi Sq5 windshield and front side windows. Wow what a difference in the comfort level and interior heat after being parked out in the hot Georgia summer sun. Just my 2 cents.
Stuart S (06-25-2018)
My choice was white
My car choice was white and I blacked out all the silver have a look...
https://www.jaguarforums.com/forum/x...-forum-201121/
The car I bought was not my first color choice. Initially I was looking at the darker reds like Caviar. Wanted the London Tan inside for sure.
I ended up with a Stratus Gray exterior. Was not even on my short list of colors but the car was just too good to pass up. Now that I have had it for about 18 months I am really happy with it. It always looks good even when dirty. And it has specs of green and magenta in the paint that are seen in the sun. At night it looks nearly black and elegant. Who'da thought such a bland sounding color would be so versatile?
If I had to decide between black and white I would go with white just because it is much more rare to see on the road. White on white would likely be even more rare. Plus you do get the better heat dissipation.
And I rarely see X351s anyway. So far only seen 8 of them on the road in 18 months (4 black, 2 silver, 2 white).
QP7 (03-17-2024)
