Compression spec for 5.0 na engines, please
Received 3,231 Likes
The manual is not real specific and does NOT give any numbers!
First they shown this diagram for you to write down each cylinders readings.
Two boxes for each cylinder. You should be doing a dry test first then add a small amount of oil (10 ml) to each cylinder and repeat the test for the wet results.
But to interpret the results the manual states.
So no set number and the readings are a relative measure I guess?
Sorry not much help?
GaiaXF-V8S
05-14-2024 12:34 AM
GaiaXF-V8S
09-13-2023 09:47 AM
GaiaXF-V8S
08-13-2023 04:50 PM
GaiaXF-V8S
08-12-2023 02:50 PM
