Hi, i have a problem with my Compressor air suspension. I think they are malfunction :/
The compressor only makes a "click" when I connect 12V to the connection. And when I disconnect the 12V it makes a "click" again.
Anyone have any ideas on how I can check the compressor? I think he ran too long, maybe after the accident. But maybe i can open it and repair it. But i´m not sure how works the Compressor :/
When installed in the car, the compressor will only run when the car reaches a certain speed (20ish MPH from memory). The pump makes a lot of noise and the system is designed to use road noise to mask the compressor. The system only runs for a few seconds and only if the accumulator is low.
Your click may be the run command, or the power supply. You need both.
