Confused about ride level sensor connector
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hello all! I'm a shop manager at a Euro shop in CT. We have a 2011 XJ Supercharged that a customer brought in. It appears as though it was in a front end collision and the right front ride level sensor is broken and needs replacement. The connector is broken and my techs and I are stumped on the pin out since some genius at a previous shop decided to use all red wires and presumably wired it wrong. All the diagrams I can find say that there are only supposed to be 3 wires in the connector. Pin 1 is ground, Pin 4 is signal, and Pin 5 is 5V reference. We cannot figure out why there are 6 wires going to the sensor. Does anyone know what pins 2,3, and 6 do? We want to get this wired right but can't proceed without a further understanding of wire colors and pins. Any help is appreciated, thanks! -LukeShopManager
Received 3,909 Likes
Luke, Wire for Pin 2 is a green-brown wire that is the reference voltage ground. Pin 3 is a yellow-green wire that is the reference voltage source. Pin 6 is a brown wire is the output of the sensor to tell the computer how high the car is sitting. This would be for 1 of the height sensors. Wires 1, 4, and 5 are for the other height sensor in that block (there are 2 sensors in the one block/module). Just to make sure you have the right wiring, wire 1 is a brown-blue wire that is the reference ground. Wire 4 is a white-green wire that is the sensor output. Wire 5 is a yellow-green wire that is your reference voltage.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
km here
im a car enthusiast who has had to learn how to fix my cars myself cuz theres very few of these jags here and no trained personnel.
so my problem is the same as above except i need the wiring for the left hand side front. any help would be appreciated. regards
I have the exact same problem.... broken RH sensor connector.
