XJ ( X351 ) 2009 - 2019
Coolant drain
Old 05-07-2023 | 09:26 AM
Na5h's Avatar
Exclamation Coolant drain
Looking at doing a partial drain/fill of the coolant. Should be simple and relatively straight forward. Well, the coolant drain plug located at the left bottom corner as a '+' type slit in it. Using a regular slotted screwdriver, one would have thought turning it left to drain would be normal. However, I am having difficulty as the 'screw' does not want to turn willingly. Something had happened though, because I not have coolant dripping out very slowly. About a drop every 1 - 1 1/2 minutes. Any thoughts on how to open up the plug to drain, and, is there a replacement plug available? Part numbers if anyone has access to the info?
Old 05-07-2023 | 03:10 PM
clubairth1's Avatar
I think your right?
Maybe it's a bit stuck?
The shop manual just shows the normal Righty Tighty-Lefty Loosy drain plug.
I find these are pretty generic so take yours into a parts store and see what they have. Note they probably won't have a listing for Jaguar anyway!
Yours likely just needs the O-ring replaced and I do add a dab of dielectric or bulb grease to the O-ring to ease installation and prevent future sticking. I think it's the rubber that is dragging causing all the bind your feeling.
So don't replace it yet!
Old 05-08-2023 | 10:01 AM
Na5h's Avatar
Hi Clubairth, thanks for your feedback. I got the drain plug freed, but it did not drop out completely. Probably has a 'holder' to keep it in the drain hole. So, I am not sure if it can be replaced. I will make enquiries with our local dealer and see if their parts guys can confirm either way.
I'd much rather have one of those that are screwed in, and have a wing-nut type set up that you open to drain.
Old 05-08-2023 | 11:18 AM
XJ8JR's Avatar
I've found that using a larger Phillips-head screwdriver works best on that plug, for what its worth.
Old 05-08-2023 | 03:51 PM
Na5h's Avatar
XJ8JR, I'm not sure if a larger Phillips screwdriver would work.... The slots are just like a 'plus' sign (+) and no smooth corners like a Phillips. I'll have to look again....
Old 05-09-2023 | 08:08 AM
clubairth1's Avatar
Correct. It's now loose but must be pulled straight down again to remove it because of the rubber washer/O-ring. I usually take it completely out to inspect and to let the coolant flow out with full force. I use pliers as with the angles and such I don't have enough hand strength to muscle it out.
Glad you got it free!
Old 11-02-2023 | 02:30 PM
‘Oleguy's Avatar
Draining explained ;
I will open the petcock / drain valve allow the coolant to drain until no more leave the petcock/valve area. Retighten & refill
Old 11-03-2023 | 02:57 PM
clubairth1's Avatar
Just to follow up because I recently changed my coolant as the car past it's 10 year anniversary.
Like a lot of parts that plastic screw in drain plug is cheap and easy to get!
Dorman 61138 and they are all over and about $7. Too cheap to NOT replace!
Here it is compared to what came stock in 2014 XJR. Turns out this has been used since the 1990's in millions of Fords.
ralphwg (11-04-2023)
MrAndersonGCC
01-04-2022 11:13 AM
Bob Boyle
03-22-2021 03:46 PM
Shoreguy
09-24-2017 10:44 AM
bracester
02-28-2013 03:57 PM
Razkid
10-21-2012 02:32 AM
Quick Reply: Coolant drain
