Coolant Hose Under Supercharger?
I am planning an overhaul of my 2013 XJ 3.0 AWD soon including coolant pump, pipes, hoses, and supercharger snout replacement. I have had a lot of difficulty in the manuals and parts diagrams identifying the hose that is routed underneath the supercharger.
could someone tell me the part number? I want to replace if I’m in there. Thanks in advance!
Attached is an example image from the F-Type V6 supercharger removal tutorial:
https://www.jaguarforums.com/forum/f...tailed-241371/
I think that might be C2Z28432.
BUT first, search that part number, or call a dealership & tell them you need the part # for the hose that goes from the rear heater manifold (or cross-over pipe) to the throttle body.
...to make sure it's the one. It's one of the 2 throttle body hoses, & I believe that is the long one that runs under the intake manifold.
UPDATE - I just put eyes on one I have and I'm sure that's the one, but do your own confirmation anyway.
Oh my goodness, removing the supercharger from the engine intake was a piece of work! I ended up cracking one of the clips that hold this hose to the underside of the supercharger…it was baked pretty good I bet, one touch of my pliers did her in. Hopefully it’ll be ok! I’ll plan to zip tie to the rear heater manifold to prop it up a bit.
The clip broke off of mine when I took off the blower.
Can anyone confirm if the new hose does indeed come with the clips attached?
Much appreciated!
- C2Z22073 Lower Cooler Hose to Thermostat (under supercharger)
I used a black zip tie on the back side to the rear heater manifold to lift up this hose since the back clip broke. I would definitely order both clips if you can find the part number. Not a place to zip tie on the front.
Hi this is the part number, and no it does not come with either of the two clips:
Here is a picture of it.
Jaguar Clip
Looks like about $2.50 and is a current good part number at any dealer.
Jaguar Clip
kr98664
12-31-2022 02:56 PM
Razorbladehaze
04-30-2018 10:05 AM
