XJ ( X351 ) 2009 - 2019
Coolant leak from plug-in connector in front of water pump
Old 04-12-2019 | 08:04 PM
Imeri's Avatar
Default The plastic L fitting
Hey guys , going through all your photos and comments those part numbers didn’t exactly solve my problem. Was wondering if anyone knows what this part is called or part # for it ?
I seen a comment about having to buy a whole new water pump ? I hope this isn’t the case my water pump is fine .. I own a 2012 jaguar XFR
Old 04-12-2019 | 09:19 PM
Imeri's Avatar
Hey did you ever find out what that Elbow fitting was called ? Im looking for the exact same thing..
Old 04-13-2019 | 09:39 AM
Brutal's Avatar
jaguar sells this as a updated piece that changes routing and includes and comes from the hose between the t stat and outlet pipe. No I don't have the part numbers I don't work in parts for the next question that always seems to get asked next, do some of the research yourselves...
Old 04-16-2019 | 06:36 PM
hafren's Avatar
Have a look at the attached, a pictorial of the revised coolant routing Brutal mentions (to overcome the volume of pump failures) and the broken part you mention is part of the old hose AJ812141 but I'm not sure that is still available. That part is now included with part # C2Z28467.
File Type: pdf
Erhead64 (03-15-2023)
Old 07-19-2019 | 06:58 PM
XJ8JR's Avatar
Has anybody found a source yet for that plastic female connector? I was replacing the big hose that the little hose is connected to and of course the whole fitting on the water pump cracked to hell. Please don't tell me I have to replace the whole darn thing now. There must be a source for the o-ring and connector.
Old 01-13-2020 | 09:38 PM
kennlom's Avatar
As of 2019, part# is LR045238. This will fit the Land Rover and Jaguar as well.
leaddog11 (01-25-2023)
Old 01-14-2020 | 03:33 AM
Gonfry's Avatar
Default Hi Imeri, I found plug-in L Connector.
[QUOTE=Imeri;2054432]Hey guys , going through all your photos and comments those part numbers didn’t exactly solve my problem. Was wondering if anyone knows what this part is called or part # for it ?
It is attached to end of small hose on part number LR049989 LandRover Thermostat water outlet 5.0L
I cut part of the rigid plastic hose and connect rubber hose that is connected to L Connector. I had to purchase new water pump because I could not find plastic O ring connector that comes with pump. This is how I solved coolant leak at L connector in my 2011 FX Supercharged
  #28
Old 01-14-2020 | 12:39 PM
clubairth1's Avatar
Thanks for the part number!
It's not easy to find for sure.
Old 01-23-2022 | 11:19 PM
GoFaster's Avatar
Just adding on to this long asleep thread, I did a workaround for this... I very carefully removed the plastic stuff from my waterpump, tapped the brass piece the plastic goes into and screwed in a brass 90° , but the trick is the plastic is also a check valve, bought a couple of metal check valves for fluid off Amazon for a couple.of bucks and put it inline. I then just ran a new hose with a little extra hose to allow for the valve as my plastic hose was as brittle as glass
Tapped pump and brass 90
Check valve.
The following 3 users liked this post by GoFaster:
Erhead64 (03-15-2023), Reaxions (04-05-2022), XJ8JR (05-05-2022)
  #30
Old 04-30-2022 | 09:12 PM
JMoreno's Avatar
Check valve.
i need this!!!!!! I’m dealing with the same issue, any chance you can provide some details on what you used ??
  #31
Old 04-30-2022 | 09:44 PM
GoFaster's Avatar
The brass 90degree i sourced at the local auto parts store and was very careful tapping it just a little, then backing off and tapping some more. So the tap didnt bite too much and loosen the brass in the pump. If it had inwould have drilled the brass then tapped the actual pump body. The 1/4 one way valves are in the included picture, just use a little extra hose to allow for routing with no kinks.
Amazon is my friend lol
XJ8JR (05-05-2022)
  #32
Old 05-01-2022 | 01:36 AM
JMoreno's Avatar
Any chance you can provide a picture of the final product all put together?
fyi; you’re a godsend 🙏🏼
  #33
Old 05-03-2022 | 09:28 AM
GoFaster's Avatar
Just a little note, due to the plastic hose getting very brittle and non elastic, I used a razor to cut the hose from the other connector so I did not chance breaking the connector. I will see if I have a solid picture of the finished product.
  #34
Old 05-03-2022 | 05:38 PM
GoFaster's Avatar
Water pump 90 degree using fuel line grade hose
Runs to the valve then just a loose loop to ensure flow
Hose runs back to the "Y" pipe.. thats all!
  #35
Old 05-12-2022 | 08:58 AM
leaddog11's Avatar
Great, detailed info here. Thanks
  #36
Old 10-20-2022 | 08:38 PM
takeoverrover's Avatar
Default Find?
I just had this happen to me and I was wondering if you ever found a replacement or an alternative solution please don’t tell me I’m gonna have to replace my whole water pump as it is perfectly fine. Thank you!
  #37
Old 10-21-2022 | 09:59 AM
clubairth1's Avatar
You can also replace the factory plastic part with a brass replacement.
Here is the listing if you are interested?
Brass Replacement Part
XJ8JR (10-21-2022)
  #38
Old 10-21-2022 | 11:47 AM
XJ8JR's Avatar
Unfortunately, no, I had to replace the entire pump...but that was several years ago. It seems like there are a few alternative choices now.
  #39
Old 01-24-2023 | 03:12 PM
Sabrinaservicewriter's Avatar
Thermo, you are correct. We have tried multiple times talking to our parts department at the local dealership and were told the same thing. It is part of the water pump. I wish they would make more parts serviceable but the engineers design it and mechanics have to fix their mistakes. Maybe one day Dorman will start doing a better job of making Jaguar parts
  #40
Old 01-25-2023 | 08:05 AM
leaddog11's Avatar
Paulc732
01-20-2024 10:45 PM
pdfisherman
08-22-2016 12:20 AM
Kewpie
02-20-2016 06:50 PM
leaperjag
07-13-2009 09:31 PM
alckc
06-12-2008 09:10 PM
Quick Reply: Coolant leak from plug-in connector in front of water pump
