Could this be the BCM?
Ive owned this 2011 xjl for about 6 years now
, and suddenly all these stopped working almost at once. Sound/radio doesn't work, drivers seat stuck in position, massage seats don't turn on, automatic windows don't roll up or down, and trunk doesn't close with the button anymore
@Lightspeed
No flash, completely stock. Dealership did do something to the computer a couple months back, but that was for an airbag recall
The "U" fault codes are all network related. Check the service manual to see what network they relate to. For instance the medium speed CAN communication network needs to 'see' a network termination of 60 ohms. Possibly something has come disconnected and is affecting all modules.
The central junction box (CJB) is located behind there and certainly is worth a look as the medium speed CAN bus runs through this. It also runs through a number of other modules too as you'll see in the service manual. The mechanical connections can suffer from oxidizing on the pins - Mine did and kept suffering network problems, boot open faults etc. I used a small Dremel with a small wire disc to clean the male pins on the CJB, door control modules, A/C front and rear, keyless vehicle module as they all run on this network. That was 2 months ago and had no faults since. Remember to disconnect the battery if doing this to prevent shorting out anything. I used CRC co contact cleaner on the female end of the connectors before plugging back in. No guarantee any of the above will fix your issue but certainly won't hurt to try.
Stuart S (12-09-2022)
Your Public Profile shows that you're in the USA but doesn't show the state or city. You should add that so we can better help you. Extreme heat or cold can kill a battery.
Take your XJ to any national chain auto parts store and they will load test your battery for free.
https://www.autozone.com/lp/battery-services
https://shop.advanceautoparts.com/o/...attery-install
It's almost always the battery.
XJsss (12-10-2022)
If you find oxidation in a plug or on pins I found that Deoxit will eat the corrosion up without scrubbing. I was very surprised at how thoroughly it cleaned the electrical plugs. It's a bit expensive but compared to other contact cleaners I find this to be the only one that removes the corrosion.
Deoxit Spray
Deoxit Spray
Got a new battery today, didn't change anything. Also went through the CJB and none of the male pins seemed oxidized. I've set up an appointed with a diagnostic shop to see if maybe they could figure out what's going on. Thanks for the time and effort everybody put in though!!
If you have access to a diagnostic tool....first thing to do is clear all fault codes, drive (if you're able) and then have a look at the codes that reappear and compare with your pics on your first thread. That way you'll know what were historic codes and what is currently causing you grief.
