Daylight running light LED in headlight hack
It seems to be still attached - or has been reattached - to post #8 and post #19. (at least it works for me - beware it downloaded as "Jaguar 351 Signature lights hack.docx.dot", and so may have done a disappearing act on your machine, or your machine may have blocked the download of a ".dot" file)
With hardly a pause for breath, I leap into a response:
Just completed this "HACK" on my 2014 XJL, center wire on the clip side of the connector. I used 2 SPDT relays so I only had to run one wire ( switched +12v) to the drivers side. my relays had a metal mounting tab and there is a flat plate directly behind the headlight with a small hole that I used to mount them, a small bolt with a locking nut worked perfectly. I also tapped into the switched 12v in the fuse box, had to use a different fuse, one shown was not switched, used the one to the right and added a dedicated in line 3A fuse. Everything seems to be working, do have a delay in turning off of the LED's but not an issue. Thank You to GEARS for this post.
skylark2001 (07-07-2018)
#28
Led lights
Hi
I have wired this up but it wont work.
Cant source the tyco relay.
pin outs on mine are as follows.
pin Configuration:
Pin 1: Pole A - Normally Closed (NC)
Pin 2: Pole B - Normally Closed (NC)
Pin 3: Pole A - Normally Open (NO)
Pin 4: Pole B - Normally Open (NO)
Pin 5: Pole A - Common IN
Pin 6: Pole B - Common IN
Pin 7: Coil Side A
Pin 8: Coil Side B
Will it be the same wiring?
thanks
Tony
pin Configuration:
Pin 7: Coil Side A
Pin 8: Coil Side B
thanks
Tony
