Diagram of the Jacking Points on XJL with floor jack?
If you look under the car, just behind the front wheel and just ahead of the rear wheel there are arrow-looking triangles pressed into the plastic, pointing out the jacking points. On the front, I insert the jack into that sunken square indent. You can touch it and it is metal as opposed to most else around being plastic. At the rear I set the jack just inboard of the little triangle on the vertical reinforced metal structure.
Andrew Fanshawe
04-04-2017 12:51 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Richard_gib
09-12-2015 07:08 PM
1964Daimler
09-09-2015 11:28 AM
