disable auto dimming interior mirror rear view
The rear view mirror sensor triggers the dimming for itself and the door mirrors, and the X351 has two sensors (forward and rearward facing). The front sensor is for the ambient light level so it can detect the difference between the two, so simply covering the rear one will disable the functionality.
If you do not have the blind spot monitoring system you can pull fuse 3 (5A) from the rear (trunk) fuse box to disable the mirrors.
Otherwise it is not as simple as just disconnecting the sensor as it is integral to the mirror itself. Instead a hidden solution is to bridge two pins at the mirror connector. Pin 1 (grey) to pin 2 (white with brown stripe). That will permanently enable the reverse inhibit signal which prevents the auto dimming activating when the vehicle is in reverse.
someguywithajag (09-13-2021)
Colour me baffled as to why anybody would want to disable auto-dimming.
I have just returned from a trip to the Dallas-Fort Worth area where maladjusted low beams or permanently on high beams seemed to be a popular way to proceed.
My rental car did not have dimming mirrors so more than once I was almost totally blinded by some brain donor behind me.
![Icon Special](https://www.jaguarforums.com/forum/images/smilies/icon_special.gif)
![Icon Badrazz](https://www.jaguarforums.com/forum/images/smilies/icon_badrazz.gif)
dsetter
12-11-2016 12:54 AM
