Do headlights fit from xf cars?
Does anybody know if XF headlights fit for 13 + xj cars? They look very similar
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
Definitely not. But you can retrofit the later model LED XJ headlights. You can either buy them plug-and-play from someone who's already done the work or you can create the wiring harness yourself. I had no previous wiring or electrical experience but was able to successfully make the harnesses using XDave's diagram and instructions. Run a search and you'll find the thread. The updated headlights really made a big difference.
