Do I have a bad battery?
I recently purchased my first Jaguar. It’s a 2015 XJL with 13,000 miles. I don’t drive it every day, but I’ve noticed three messages that say battery low start car. I bought the car in New York and brought it to Florida. I spoke with a gentleman at the mall yesterday who has same car. Asked about the messages, said he had the same issue. Took it to his dealer and they replaced the battery under warranty. I called the same dealer this morning, and they told me this was normal. Do I have to keep a battery tender on this car at all times? Not a happy camper! Thanks
Received 2,675 Likes
Jjdejd (11-09-2017)
I have had that warning on and off on mine for the whole 6 1/2 years I have had the car since new, it will generally come on if you maybe leave the doors open while loading or unloading the car. It is a pain to see it but I have never worried too much about it.
I do use a ctek battery conditioner if the car is not going to be used for maybe 10 days or so as it does help to keep the battery in tip top condition, it can help to prolong battery life as well. Mine is still on the original battery and the car has covered about 80000 miles or so.
Jjdejd (11-09-2017)
Received 3,923 Likes
Jjdejd, a few things to consider with this. Yes, if you drive the car only say once a week, you may see warnings like you are seeing because there are computers that run in your car 24/7/365 and they will pull a small amount of power from the battery, draining it over time. This is where most members have gone to some sort of trickle charging setup for their cars to ensure that the battery is maintained at 100%.
Secondly, as odd as it may sound, lock your car, even if you are parking it inside of your garage. The car is designed to turn off a majority of the computers when the doors are locked. If you don't lock the doors, the car remains "awake". More stuff on, more draw from the battery, the quicker it will drain.
The final thing that you need to consider is if you have something plugged into the power outlets (say a GPS unit, cell phone charger, etc). Depending on the outlet that it is plugged into, it may have power all the time and again, it will pull a little bit of power (even when not charging something), draining the battery that much faster.
Jjdejd (11-09-2017)
Jjdejd (11-14-2017)
