XJ ( X351 ) 2009 - 2019
Does not work "voice control"
Old 09-02-2017 | 01:22 PM
Mikl's Avatar
Default Does not work "voice control"
when you press on the steering wheel "voice control" turns off the sound system. The speakerphone does not turn on.Thank you
Old 09-02-2017 | 03:17 PM
clubairth1's Avatar
Can you help us out?
What car do you have?
Can you help narrow down which button you are pressing?
Old 09-03-2017 | 11:07 AM
Mikl's Avatar
XJ X351 2012
on the steering wheel to the left "voice commands" When pressed turns off the sound only. Voice control does not include.
Old 09-03-2017 | 11:09 AM
Mikl's Avatar
How to activate voice control ?
Old 09-04-2017 | 02:17 PM
TheBoy's Avatar
Have you checked if your car actually has Jaguar Voice? It was not available in all markets.
Old 09-06-2017 | 04:09 PM
JagGate's Avatar
Even if you do have it it is useless. I did not even have the patience to get through it when I was testing it out the one time I suffered through using it. Worst designed POS I have ever seen.
Old 09-08-2017 | 09:15 AM
TheBoy's Avatar
I have to pull you up on that. Its accuracy is fantastic, far better than any other car I've used.
I do use it all the time, as its far safer to use voice to set a destination, or change radio, than fumble around a touchscreen at speed.
And I hardly speak the queens English
ArtyH55 (03-14-2023)
Old 09-08-2017 | 10:43 AM
JagGate's Avatar
Accuracy is not the issue.
Old 09-09-2017 | 01:33 AM
dga57's Avatar
I've never been able to get mine to work. I painstakingly jumped through all the hoops as described in the owner's manual, only to be told that it cannot recognize me. Useless, so far as I'm concerned.
Dwayne
Old 09-09-2017 | 09:25 AM
TheBoy's Avatar
May we enquire why you think its rubbish?
Stating that its rubbish without elaborating isn't overly helpful to other people reading the posts
Old 09-09-2017 | 09:28 AM
TheBoy's Avatar
Dwayne
I'm fairly certain my book doesn't cover it. But it was so intuitive, it didn't matter. I pressed and released the button, it responded with "Say a command", so I said one of the commands listed on the dash. Then I learnt you could string some commands together. It just works.
Old 09-09-2017 | 10:28 AM
dga57's Avatar
I don't doubt you and I'm very happy for you, but mine does not work, no matter what you do. More trouble than it's worth!
Dwayne
Old 09-10-2017 | 07:09 AM
TheBoy's Avatar
Dwayne
Thats really interesting. I wonder if its more for British accent (though I'd find that unusual, its usually the opposite way round).
Old 09-10-2017 | 11:21 PM
dga57's Avatar
That's basically the conclusion I came to. The voice that was talking to me had a British accent. My U.S. accent is essentially "southern drawl" which perhaps confuses it. Any attempt on my part to imitate a British accent would probably be even worse! lol
Dwayne
Old 09-11-2017 | 08:47 AM
TheBoy's Avatar
I shall try me best Dolly Parton accent when I get back to the UK, see how it reacts.
Old 09-11-2017 | 09:15 AM
dga57's Avatar
Be sure and let me know how that works out!!! lol
Dwayne
Old 09-11-2017 | 10:02 AM
JagGate's Avatar
The amount of time and commands it takes to do anything is 10x longer than just doing it. Too many commands, prompts, confirmations, etc to do even the simplest of things. Very poorly designed.
Old 09-12-2017 | 05:29 AM
TheBoy's Avatar
You can string commands together.
But we'll have to agree to disagree. I find the voice easier, quicker and far SAFER than arsing around with the touchscreen whilst driving.
